Don't forget the balljoints, If using fox balljoints, with SN-95 spindles there's a spacer required for to properly tighten the castle nut onto the lower ball joint (.330" tall, 5/8" inside dia & 1.5" outside dia.), if using the SN-95 balljoint you're fine.
