Page 1 of 17 12311 ... LastLast
Results 1 to 25 of 417
    Default The Ultimate Four Eyed Fox 5-Lug Conversion Thread
    We've been seeing a number of threads pop up asking 5-Lug conversion questions. I will post what I know, but I need everyone to contribute what they can. I will continue to edit this post to compile all of the information you provide into one post.
    Please correct any mistakes I have made and contribute anything you feel is necessary so that I can compile your information into this post.
    Front Brakes Parts List
    Spindles/hubs
    Rotors
    Calipers with caliper brackets and caliper bolts
    brake Pads
    brake lines with banjo bolts
    brake line adapter to connect passenger sn95 brake line to fox hard line (see below)
    spacer to put over the balljoint when tightening castle nut for spindle down onto ball joint (see below)
    Front Calipers/Spindles/balljoints
    99-04 dual piston PBR calipers are better than 94-98 Calipers. If using 94-95 spindles, grinding/modification will need to be performed on the spindle to use PBR calipers with 94-95 spindles. 99-04 Calipers will bolt to a 96-98 spindle without modification, but these spindles will push your wheels out further.
    All 94-98 v6/GT calipers are the same. All 99-04 v6/GT calipers are the same. All calipers from 94-04 can be used on a fox body with SN95 spindles.
    96-98 spindles push your front wheels out further than 94-95 spindles. Are 99-04 front spindles the same as 96-98 spindles? Can anyone provide dimensions and how much the different spindles push the wheels out?
    If using fox balljoints, with SN-95 spindles there's a spacer required for to properly tighten the castle nut onto the lower ball joint (.330" tall, 5/8" inside dia & 1.5" outside dia.), if using the SN-95 balljoint you're fine. (SleeperGT)
    Front Brake Lines
    SN95 front lines and banjo bolts are needed. You will need a weatherhead fitting (or other brand fitting) to connect the SN95 passenger front line to the fox body hard line.
    Here's the brass fitting brand (1), part number(2) and size(3).
    1. Brass-Tite!
    2. 43303
    3. 1/4" female tube to 3/16" male tube "inverted flare"
    This will allow the user to make the stock SN95 passenger side rubber hose fit the 79-93 passenger side hard line.
    (silver85)
    A-Arms
    "All arms from 79-93 (except SVO) are a direct swap. The FRPP arms are the same as the 87-93 arms for the 5.0 cars with low friction ball joints as well as a gusset welded to them. The 94-95 arms are the same as the 87-88 Thunderbird Turbocoupe arms and are 3/4" longer than the 79-93 arms." (Travis T)
    Rear End SN95 Brakes Parts List
    94-98 V6 or GT or Cobra axles, they are all the same
    Dust Shields and bolts to hold them on
    2 Caliper brackets
    2 anti-moan brackets
    calipers
    brake pads
    rotors
    94-95 GT axle hard lines (for direct fit swap)
    94-95 GT soft lines (for direct fit swap)
    2 FRPP e-brake cables (part number M-2809-A). Two are required. These connect to your stock center e-brake cable. 86 and older cars came with an adjustable center e-brake cable, 87-93 Mustangs did not.
    Rear Calipers/Brackets
    All 94-04 V6, GT, and Cobra rear calipers are all the same. 94-04 V6/GT rear rotors, pads, and caliper brackets are exactly the same. The difference with the Cobra brakes is a larger rotor, thinner brake pads, and a different caliper bracket that will position the v6/GT caliper over the larger rotor.
    Rear Brake Lines
    For an OEM fit/finish, 94-95 GT axle hard lines are the perfect size for a fox body rear disc conversion. No bending, cutting, or flaring is needed when you use 94-95 rear hard lines. 94-95 GT rear soft lines should be used and can be purchased brand new from Napa for about 15 dollars per side.
    You can use your stock fox body rear hard lines, but they are too long and will need to be bent out of the way, or cut and reflared.
    94-95 V6 rear hard lines, 96-98 v6/gt rear hard lines are not the same as 94-95 GT hard lines and require some modification to be used.
    Proportioning valve
    SN95 V6/GT master cylinder
    Gut the stock prop valve and replace the end cap on the proportioning valve with the FRPP end Cap(part number M-2450-A) and purchase a Wilwood or summit adjustable proportioning valve.
    Master Cylinder
    To keep things easy, you can use any SN95 V6/GT master cylinder. (Other master cylinders can be used.)
    Brake Booster
    larger brake booster from a 94-95 V8 or V6 or a 96-98 V6 or a 93 Cobra.
    It is impossible to install a larger brake booster into an 86 and older fox body without massaging the strut tower. Do not beat the strut tower with a sledge hammer. Proper massaging procedures should be used to avoid damaging the structural integrity of the strut tower. Improper massaging techniques will produce negative results and can lead to the sheet metal cracking.
    The SN95 brake boosters have a stud pattern that makes it difficult to install the booster onto a pre-87 Fox body. It's not impossible, but it is significantly more difficult. You will need to massage the strut tower and significantly elongate the brake booster holes in the firewall.
    You can purchase a remanufactured 93 Cobra brake booster from a carparts store like Kragen. The manufacturer is Cardone. This brake booster is the same size as the SN95 brake booster but retains the fox body brake booster stud pattern. You will need to massage your strut tower. You may need to elongate the holes in the firewall slightly, depending on how much your clearance your strut tower.
    Not required but recommended
    Rebuild your stock a-arms -
    Moog replacement balljoints for an SN95 or Steeda X2 balljoints
    Replacement a-arm bushings or energy suspension a-arm bushings
    or
    Purchase FRPP replacement a-arms - keep in mind these are longer than stock fox body a-arms and will push your wheels out further.
    5-Lug rear drum brakes
    You will need axles from the following vehicles
    2 passenger side aerostar axles
    or
    driver side Bronco II? (which years and sides?)
    or
    driver side ranger axles? (which years and sides?)
    Aerostar drums are 10 inch. If you want to upgrade to 10 inch rear drums, snag the aerostar drums and backing plates as well. Otherwise, you will need 9 inch 5 lug rear drums from the above year Bronco II or Ranger
    Corey
    1965 Mustang
    1986 Mustang GT T-Tops - Explorer engine swap, MAF Conversion, 5 lug Cobra Brakes
    2001 True Blue Bullitt
    www.thompsontransmission.com - coming soon
    Fox Body Black Interior Interchangeability Guide
    Travis T
    Guest
    Quote Originally Posted by 50 Proof View Post
    A-Arms
    What are the differences in size between 79-86 a-arms, 87-93 a-arms, 94-05 a-arms? Are the FRPP A-Arms the same as OEM 94-04 A-Arms?
    Thank you, original post has been edited to include your screen name as the source
    Corey
    1965 Mustang
    Travis T
    Guest
    But now everyone knows who to blame if it's wrong.
    haha exactly
    I just wanted to give everyone credit who provides info, that's all.
    Corey
    1965 Mustang
    FEP Senior Member SleeperGT's Avatar
    May 2002
    NS, Canada
    Don't forget the balljoints, If using fox balljoints, with SN-95 spindles there's a spacer required for to properly tighten the castle nut onto the lower ball joint (.330" tall, 5/8" inside dia & 1.5" outside dia.), if using the SN-95 balljoint you're fine.
    '83 Mustang GT
    By how much are the FRPP A-arms longer than the 79-86? I have the FRPP A-arms on my 85.
    And what to the gussets do? Are they for added strength? I'd think they'd do that for added strength... right?
    May 2002
    NS, Canada
    The e-brake cable #'s for the SN95 rear disc swap are M-2809-A. Two are required. Thanks for correcting me guys!!
    '83 Mustang GT
    Jan 2006
    Bowling Green, KY
    For the front, the cheap way that retains the fox spindle and brakes is to run a 2wd 84-90 ranger front rotor (for all 2.3 cars and v8 cars >1986) or 85-86 SVO/Mark VII front rotors (1987+ V8 cars)
    In the rear, ONLY the 7.5" axle equipped rangers/areostars will work, if it has 10" drums (7.5" axles have 9" foxbody size drums, which swap directly over) it has an 8.8" axle with more offset and the axles don't fit. the 28 spline units in the 8.8 and 7.5 axles are the same strength, the 7.5" just has a smaller ring and pumpkin.
    A word of caution, if you swap rotors to get 5-lug, your wheel choices will be limited as after 1998 Ford phased out greasable hubs and went to the sealed hub design with no spindle cap, thus making their wheel designs shallower (your flashy cobra R's won't fit over the ranger or SVO hubs) I know the 97-98 cobra wheel, 16" pony, 17" tri-bar and the v6 wheels will fit, others its hit and miss.
    79 Notchback Capri 5.0/TKO - Sold
    88 GT TTOP 5.0/5spd - Sold
    86 GT 5.0/5spd Boltons - Sold
    89 LX Vert 5.0 5spd - Sold
    89 LX 2.3/Auto - Sold
    95 5.0/5spd boltons wingless & no power options
    5.0 resto has a whole kit for like $400(axles includede).
    FEP Power Member kj_80Cobra's Avatar
    Feb 2006
    Harrisonburg, VA
    Quote Originally Posted by SleeperGT View Post
    The e-brake cable #'s for the SN95 rear disc swap are F3ZZ-2A635-A. Two are required. 1993 Cobra Units.
    Those cables are only for a 1993 car. You need two FMS M2809A rear cables for all 1979-1992 cars. If you have a 1979-1986? (whenever they changed the e-brake handle to the ratchet gear type) you do not need the front FMS M2810A cable, all 1987-1992 cars will need the front cable and will need to modify their e-brake handle ratchet gear.
    This is specific only to the 93 Model cars. 79-92's use the FRPP cables M-2809-A. They are $27.95 each, 2 are required per car. The 79-86 cars do not need the intermediate cable M-2810-A. That small cable is specific to the 87-92 cars.
    The plug for the proportioning valve is the M-2450-A. I've read of a possible design change due to the newer proportioning valves going to a metric thread. I've got one from about 7 years ago that I can post a pic of. I'll try to make note to do that as well as gather a pic of the newer version. This directly affects a majority of the FoxChassis cars because of their age.
    I've got the specific adapter size for the passenger side SN95 hose on a Fox. I kept the little package that it came in so I'll have a specific brand part number and sizing. I'll post it when I get home. It's still on my workbench.
    lol!!! someone was reading my mind!!
    Great, thank you to everyone who has responded, I'll update the original post tonight when I get home.
    If anyone has anything to add, keep the replies coming.
    Corey
    1965 Mustang
    1. Brass-Tite!
    2. 43303
    There are a couple of companies that make stainless steel braided lines specifically for the FoxChassis cars with an SN95 conversion. Those brake lines are designed to fit without any fittings.
    great thread! Anyone have cost estimates from what they spent so I can see if this is an immediate reality or not for all of us poor 4 lugger folks?
    Jeremy
    -66 Mustang, bench seat car,8.8,t5,crate roller 5.0
    -1990 Bronco, 5.8 roller/AOD swap in progress, 4" rancho lift, 33's
    Are there any big problems if you dont gut the stock proportioning valve? i did a 5 lug conversion to my 83 and used the stock prop valve with no modifications and the stock booster..i did put on an 85 lincoln towncar master cylinder..and the only problem ive ran into is that the pedal is sometimes hard to press..its not impossible to press and stop just kinda hard unless im cruising at a higher RPM or i rev the motor to raise RPMs...anyone have any advice on this?
    FEP Senior Member Moving_Target's Avatar
    Mar 2005
    Saskatoon, SK
    Anyone doing the rear conversion will need a couple of spacer rings that fit between the axle pilot and the rear disc rotor to center the rotor if a person J/Y sources the Aerostar/Ranger axles. Otherwise, they'll have to get a pair of 5 lug drilled 79-93 length axles but with the SN95 center pilot.
    '86 Notch autocross beotch ( bucket of rust)
    '94 Crown Vic Winter Beater
    '93 Mustang Hatchback 2.3L 5spd
    IS there a special adj port valve to be used?
    If I were to degrease my car, i'd have nothing....
    Someone should also go over the turbo coupe rear ends, and the lsc rears
    Can 94-95 front control arms be used in place of 79-93 ones? They are quite a bit cheaper than the fox arms, and although I hear they are a little longer, aren't the control arm mounting points positioned more inward on 79-90 foxes? Wouldn't this make the front track width closer to what a 90-93s track width is? I need new ball joints and bushings, and the sn95 control arms are quite a bit cheaper than the fox control arms, so if possible I would like to use the cheaper arms.
    1979 Mustang Indy 500 Pace Car
    Modified Mustangs Aug, 2006 Feature Car
    2015 F150 2.7 Ecoboost
    It was about 1000 - 1400 for my set up. most used parts and sum new.
    1988 lx vert
    Rebuilt enigne with gt 40 head's and intake's.
    ffrp aluminum radiator, mm subs, pro3i adj lower arm's, frrp 373, flowmaster catback, Magnaflow catd X,75 pro m menter. and more stuff.
    Soon to come new black top. (this summer)
    Updates have been made. Thank you so much to for all of the contributions. Once again, if anything in my original post is left unanswered, if i've left out any information, or if anything is inaccurate, please let me know.
    I don't have too much information on the non-SN95 5 lug upgrade options for our four eyes. Some people have begun to post some information. If anyone has more information on whats needed for non-sn95 5 lug upgrades, please post what you know.
    Thanks again, this thread is turning out to be a really great source of information.
    Corey
    1965 Mustang
    FEP User twistin's Avatar
    Nov 2006
    British Columbia/Canada
    On my 86 I ran 03 lower control arms and had to update the inner and outer tie rods to longer ones (03 as well) if not I would not have had enough thread.
    I would recomend to anyone that is wanting the rear disc's; to refit the SN95 calipers onto there original diff as wider tire range is available without custom rims.
    Travis T
    Guest
    Quote Originally Posted by Marz View Post
    They are the same length as I stated above, they are just the 90-93 stock arms. The gusset is to resist flex in the arm.
