I was wondering what you thought of BBK Headers?
I've loved every set I have had.
Headers are on my short list after I pull the smog pump and tubing out this winter.
I think I'm going to try and track down a set of FMS shorties to match my H Pipe....but I'm here for the reviews of the BBK's since they would be pretty and new if I went that direction.
I've seen a few instances where there was some clearance issues with the steering shaft and the BBK's which I'd like to avoid.
"YEP, SITE'S BROKE"
MIKE'SVO86 is selling a set of BBK unequal length headers in the classified section.
83 TC "Clone"
85 Marquis LTS
86 LTD Wagon
Been running them on the Capri for many years.
'86 GT - weekend driver
'86 Capri 5.0
'86 Turbo Coupe
'17 Mustang GT
'23 BRONCO
When I first went through my car years ago, I bought a set of BBK shorties...which I sanded down and coated...and matching H-pipe. They were okay, but I have GT40p heads on the 5.0L power plant, so there were a couple of plugs I had to contend with. Couple years later I found a really nice set of Ford Racing stainless shorties and a nice X-pipe unit. The header fitment is better on the FR units...especially at the heads...but the BBK's were fine. I've heard the cheap Ebay stainless shorties are good and seem to also work with the GT40p heads...maybe they're a knock off of the original FR units...
HAD
HAVE
I recommend you not do that if you're using an old style factory H-pipe with the 4 cats. The rear catalytic converters (the two-way, or oxidation, cats) require the extra air from the air pump to complete their catalytic reaction. Without the extra air, the honeycomb structures inside the converters will eventually clog up with "unprocessed" hydrocarbons, affecting driveability, performance and emissions.
Gotcha. Yea, now I remember reading that you had changed your exhaust.... didn't remember what to though. No gas smell w/o the cats?
Assume you're just trying to clean up/de-clutter the engine compartment. Hope you're not trying to do it for horsepower gains, cause it only uses about 1 to 1-1/2 hp at wot. 2-3hp when it's pumping against back pressure.
Are you going to remove the air injection pipes from the back of the heads? Or just cap or crimp them off? If removing them, you'll need something to plug the 5/8" threaded holes. Bolts will work, or...
https://www.amazon.com/gp/product/B0...HON4LEIE&psc=1
She definitely smells a little more, but I actually quite like it in a weird way. Reminds me of the way my dad's old Chevelle smelled.
I'm doing it primarily to de-clutter and remove a moving part that doesn't need to be there, not for any noticeable power gain.
Yep - Going to remove the crossover pipe. I ordered these:
https://lmr.com/item/LRS-9449-BP/mus...late-kit-86-95
I heard they can be pretty gunked up with carbon so I figured those would be easier.
Not to hijack the thread - but another reason for removing is that it'll be easier to install headers! :-)
"YEP, SITE'S BROKE"
I got a set of the sliver ceramic coated unequal shorties. They look nice and a fine quality to me. But I have no input on actual installation or usage because they are just another piece in my giant parts pile.... for my future build.
However, I am going to clean up/smooth out the weld beads on the inside of the primaries. I got that idea from a guy over on StangNet.... he did his and they look much better. He also enlarged the opening on the ball end of the collector a bit (from 2-1/4" to about 2-3/8"+), but I don't plan on doing that.
I have had a few sets ”shorty and equal” of the ceramic coating ones myself over the years and never had any issues. cats off and straight pipe. With a pair of dynomax mufflers and 2 1/2” rear pipes sounded beautiful.
I installed an Explorer GT40P headed engine in my 83.. I purchased a set of the " chinese " shorties off of Amazon for $81 that advertised " will work with P heads", figuring at that price I will take the gamble... I think they were very well made and fit well..... There was no hammering on tubes or steering shaft problems... On one side the collector was a bit close to the bellhousling and I took a grinder to it and took off a 1/4" or so for better clearance....
I purchased some Ford Racing headers and installed them due to all of the " hype " about them fitting so well....
they did not fit any better than the cheapy set I had on it...
Do yourself a favor and purchase the Trick Flow spark plug socket, it makes life alot easier when you have headers......
https://www.trickflow.com/parts/tfs-90500
Doesn't look a traditional socket, needs a wrench on the end of it
'86 Capri 5.0
'86 Turbo Coupe
'17 Mustang GT
'23 BRONCO
The socket is short and has the end open so the tip of the spark plug comes out.. Seems as if most headers ( and some old stock exhaust manifolds) had at least one spark plug that you needed an open end to tighten or loosen it.. Most of the header tubes interfere with getting a full size socket on the plug, this socket fixes that... Yes, this socket slips over the spark plug and requires and open end on it to work.... It is for the final tightening or the initial loosening of a plug.. Hopefully after that you can spin them out with your fingers or some tubing stuck on the end....
... My 67 Dodge 440 with stock HP exhaust manifolds took most of the day, getting half the plugs from under the car with an open end wrench... so these seem pretty simple to me.....
85GTguy, that TF socket is for LS engines, so I guess headers suck all over.... LOL
ok good
