Hello there...
I'm about to replace the rack in my 93 with a brand new 10:1 sport ratio unit from LMR. My question is about the steering shaft itself.
Would it be easier to undo the shaft at the firewall bolt and pull it all out as a complete unit?, does the rag joint even fit through the K-member?
What is be best way to tackle this little project?.
Any help will be appreciated.![]()
