Page 3 of 3 FirstFirst 123
Results 51 to 56 of 56
  1. #51
    Got some 10 holes and good tires on there. Swapped in a UPR quadrant. New battery and then we diagnose the tip in , bog down issue!
    1982 Mercury Capri Godzilla swapped/T56
    1984 Mercury Capri RS T-Top, 4.6 Terminator Whipple
    1979 Mercury Capri RS Turbo, SVO powertrain..(under construction)
    1979 Mercury Capri RS Bright Yellow
    1983 Mercury Capri RS 21k original miles
    1985 Mercury Capri Mclaren Convertible
    Check out my youtube channel for Four Eyed Fox stuff!
    https://youtube.com/@401foxbody
  2. #52
    Perfect. Im from Downunder, and the car looks great.
    for others...
  3. #53
    So, its been a journey! I even started a youtube channel documenting the build. I finished alot. Got the car all dialed in, making 14lbs of boost. Premium mode is wired in, and everything works. Im excited to start another project soonName:  AEB2A6BA-F5BD-4522-B90E-6F24BB5D89FA.jpeg
  4. #54
    Here is a link to the channel with more videos there. All issues have been sorted. The car is a blast to drive!
    THE 1979 MERCURY CAPRI RS TURBO' HITS THE ROAD!
    https://youtu.be/VeEwV3A9uSMName:  88BC7F97-3247-4782-836A-C51E5BD3FE84.jpeg
  5. #55
    Did the SN95 throttle body swap!
    I feel as though it helped with some driveability and throttle response. Im happy!Name:  ADFBA9B1-548B-4487-B1CA-54DCFD550E0C.jpeg
  6. #56
    Still having fun with this car!
    Had an issue with gauges being erratic, and i couldnt get a good fuel gauge reading. Swapped in the printed circuit board for the cluster from NPD. Also wired up the Turbo light to a Hobbs switch to illuminate when under boost, just as a geek feature.
    Next on the list is a 3” cutout and hunt down a pinion bearing issue (i think) at accel. Other than that, this is still such a fun car to drive. Tuning it mechanically right now, no software or aftermarket system. Just using timing, fuel pressure and a Sneec. i have another Capri project going on as well, but this one is still fun!Name:  76F46797-9A61-488F-AB3D-06170459C080.jpeg
Size:  101.9 KBName:  C7E11950-67C0-42C2-A7A8-30D4AAE7088C.jpeg
