Results 1 to 3 of 3
Thread: Reverse lights
    Default Reverse lights
    Hey guys, I swapped my 1983 mustangs srod for a t5 out of a 94 mustang a little while ago. The reverse lights donít work, I have the 2 pin pig tail for the t5 but the srod harness is a 4 pin plug. Just looking for some knowledge and pointers from you foxbody gods before I dive in with my power probe. Work smart and not hard is what I was told to do. Thank you in advance.
    On my car there is also a 4 pin harness. 1 connection goes to the reverse lights, 1 connection goes to the starter solenoid. I figured that out with my power probe.
    On my car it looks like red/light blue wire goes to and from neutral safety switch to starter solenoid, and reverse lights go from white/pink to the reverse light switch, to black/pink from the reverse light switch to the lights.
    Not sure if that helps or not?
    Helps a lot thank you !
