Ok.. I'm probably REALLY going to regret all of this.. but here goes.
*I promise that if you read this thread and you didn't already think I was certifiably crazy, you will by the time you're done reading*
About 9 months ago... give or take, I got totally fed up with the fact that my 82 was getting to a really nice point mechanically and I was still embarrased by the looks of it. I mean.. it's an 82 GTT afterall. (and yes, I am hereby coining the term GTT to reference any and all Mustang GT T-Top cars from 81-88...lol)
So here's what I have to work with. I bought my GTT back in 04 and have done the following so far. *I noted which items were done by previous owner as well
Lifelong Dallas, Texas Area "rust free" vehicle
1982 Mustang GT T-Tops w/factory A/C
Engine
New 87-93 Spec Roller Block 302 at 61,982
B303 Cam
Edelbrock 650 Carb
Holley Street Dominator Intake (custom paint!)*
85 Steel Cam 302 Distributor
Hi-Flow Polished Water Pump
Polished Aluminum Underdrive Pulleys
Holley Blue Electric Fuel Pump
Braided/Custom Formed Fuel Lines
Ford Racing Timing Chain Set
MSD 6AL Ignition
MSD 8.5 Wires
MSD Blaster 2 Coil
Factory A/C Converted to R134a*
Drivetrain
Rebuilt CHP Edition World Class T-5 Transmission
King Cobra 10.5" Clutch
Steeda Billet Clutch Quadrant
Billet Shifter Knob/Trick Stick Shifter
Suspension
Ford Racing "b" Sport Springs (dropped 3/4")
MacPherson Struts/Shocks
MAC Adjustable Billet Caster/Camber Plates
17 x 9 Black Cobra "R" Rims
AGR Street Rod Rack & Pinion
Poly Sway Bar End Links
Poly Trans Mount
Poly Motor Mounts
Weld-In Subframe Connectors W/Steel DS Seat Support Plate
Exhaust
BBK Shorty Headers
H-Pipe
Flowmaster Mufflers
Mac Flow Tubes
Electronics
Alpine Alarm w/radar
Alpine CDA-7892 Head Unit w/Aux Adapter
Sony PSP MP3 System
M.A. Audio 6 Channel 1600w Amp
Custom Amp Rack and 12" Enclosure
12" Kicker CompVR Dual Voice Coil Subwoofer
Cadence 1 Farat Capacitor
Paint
Engine/Accys Painted by Owner(myself) and Dan Hunt/Paris,TX
Exterior-(in progress) Wal-Mart Red Spray Paint and Rustoleum Clear Coat Enamel with various processes during application. Rear section car will be completed after new doors,disc rear end, and larger gas tank are finished to go in.
Extras
85 GT Interior for red instrumention*
Complete 85 GT Wiring Upgrade througout car*
Custom Rear Bumper Cover Support
Extreme Dynamat From Door Jambs Back.
Fuel Lines Relocated to avoid vapor lock w/tru dual exhaust mod
T-Top Doors Reinforced with Ford Kit
Ok.. that sums up my GTT
Here's some of the "before" pics..
As you can see. The front air dam was just pretty crappy overall. Had a small tear that always worried me over 100 mph and the paint was flaking mile after mile.
The biggest thing was that the ..ahem.. moron, had filled in the area for my pony (on the hood)... my guess is this was pre-ebay era and the guy thought he could never find the right black emblem for the 82. Shame. Anyhow, I had to deal with that, and quite a few spots on the airdam and front of the hood... from rocks, hail.. you name it.. is was pretty bad with almost 30 years of no bodywork and a couple "earl shieb" paint jobs!!
More pix...
During the initial sanding process.. (roughing up old paint) I think I used something around 300 grit with a firm sanding block to reveal major high/low spots. I also did repairs to the small tear on the front clip and filled many many holes with scratch filler. Let scratch filler dry, resand with like 1000 grit over those spots.
Also, I uncovered the filled logo hole on the hood with a wire brush attachment for my drill. It took the bondo right out.
Then I did something I'll either love or hate... time will tell. I used a product available at Wal-Mart called "self-etching primer". It seems to eat well into the old paint surface and actually "float" general low spots. After about 3 coats of this stuff (an hour or so in between) and then a good day or so drying, I was able to sand this down and pretty much only be able to see scratches. This stuff was amazing!! It seems to really level out low spots in the body and just kinda smooths everything up!
After sanding that down with a 320 grit sanding "sponge", I had an extremel adhesive surface ready for color! I applied the following...
This is "Colorplace" Fire Red (about .83/can). The method was as follows. Sprayed Hood being hung vertically from ropes, 3 coats (first one pretty light, second medium, third MEDIUM.. not real heavy!)... yes, this is SPRAY PAINT... Hrmm... think I'll tag this accordingly. About 45 min to an hour between coats. Then LOTS of drying time.... like a week. After which I sanded with same flexible type "sponge" sanding block.. (this one is about 400 grit WET sand flex block). This was the main piece I used throughout the paint and not sure where it came from. I looked and it was not readily available at the auto parts stores athough they did have 320 and lower grit flex blocks.
After first 3 coat "session"...
Now.. It's important to note again that this paint job so far has taken about 8 or 9 months... but most of that was sitting around here in Dallas waiting for the heat to break. Don't want to sweat on my work afterall!!
So, after about a week of dry time for color, you COLOR SAND. (doesn't this all sound familiar? I used alot of the same processes as the pros, but this was a very slow process and I did it fresh, never having painted much more than a manifold before!)
This is just after first color sand..
Ok.. I don't have anymore "before" pics...
The rest of the process was as follows...
On the fenders I ended up sanding back down to the primed in alot of spots, so I did second complete "3 coat session" on them (including overwindshield area) and re-sanded.
IMPORTANT!!!!
In my travels I read about how cheap spray paint has a different composition of the top coat that requires the paint be "rolled" with a flex sanding blok during wet sanding... meaning, do not "SAND" it but rathed "WORK" the paint back and forth in straight "in/out" motions.. NOT CIRCLES!! This worked so incredibly well to hide defects from the crappy paint I was using. ( on a side note, I'm doing this with cheap wal-mart spray paint to 1. See if I can and 2. Future color availability- this paint has been around forever and probably always will around!)
After entire surface has been "rolled/not sanded" with water and the 400 wet flex pad, I sprayed clear... (did I mention to have smooooth motions when you are spraying??) I used Duplicolor Premium Automotive Acrylic Enamel spray paint clear (Autozone) for the hood and front bumper cover/airdam. However, after seeing that this crap turned out with WAY too much orange peel, I switched to Rustoleum Enamel Clear Coat (wal-mart) for the fenders and overws area. (Very little orange peel).
After the clearcoat dryed for about 2-3 weeks (not sure how long it NEEDED to cure but wanted to be safe than sorry!!) I wet SANDED it with 1000 first, then 1500, then 2000. I'll continue more in the next day or too... but I'm tired.
SI
