Four Eyed Forums
Go Back   Four Eyed Forums > Tech > Mods, Maintenance and Mechanicals
Notices
Reply
Thread Tools Display Modes
Old 05-17-2009, 10:34 AM   #1
mustangpro
mustangpro's Avatar
Send a message via AIM to mustangpro Send a message via Yahoo to mustangpro
Default 3G alternator upgrade procedures to an 85 5.0
Just got a Taurus fan for my 85. Didn't realize that I'd have to upgrade the alternator just to run it. I've found a V6 Mustang 3G alternator at a local parts yard for $40. Figure I'll grab it. What's involved with installing it into my 85? This was a CFI/AOD car that now been converted to carb/T5. How do I wire it in?
__________________
65 Fastback 5.0
83 Notch NCSHP SSP 5.0
89 Notch 5.0
94 Cobra #819 5.0
mustangpro is offline   Reply With Quote
Old 05-17-2009, 10:45 AM   #2
85-5-oh
85-5-oh's Avatar
I found this to be helpful
http://www.corral.net/tech/maintenance/130a-tech.html
I also think this site has instructions also but I could not find it
85-5-oh is offline   Reply With Quote
Old 05-17-2009, 11:37 AM   #3
mustangpro
mustangpro's Avatar
Thanks for the link. Seems everything is written for 86-93 EFI cars. Looking for specifically for our older four eyes.
__________________
65 Fastback 5.0
89 Notch 5.0
94 Cobra #819 5.0
Old 05-17-2009, 05:01 PM   #4
85_SS_302_Coupe
85_SS_302_Coupe's Avatar
I had my electrician buddy do my car. I can go out and tell you what color the wires are from my harness that i'm using but that's about all i can do to help. The regulator obviously gets eliminated.
__________________
-EVIL SSP-
'85 KY Highway Patrol SSP Coupe
Walk around/exhaust clip
The Stang
The CVPI
-David
85_SS_302_Coupe is offline   Reply With Quote
Old 05-17-2009, 08:01 PM   #5
mustangpro
mustangpro's Avatar
Quote:
Thanks! Yeah that would help out a lot. That's my challenge is the wiring part. I'm sure some wires need to be upgraded for the extra juice.
__________________
65 Fastback 5.0
89 Notch 5.0
94 Cobra #819 5.0
Old 05-17-2009, 08:12 PM   #6
85_SS_302_Coupe
I'm pretty sure the only wire we upgraded was the power wire from the alt to the coil. I'll get you pics when get the chance...my GF left our camera at her sister's house. I'll try for a cell phone pic but it'll probably suck.
__________________
-EVIL SSP-
The Stang
The CVPI
-David
Old 05-17-2009, 10:27 PM   #7
rab
im intrested in those pics too.
rab is offline   Reply With Quote
Old 05-17-2009, 11:10 PM   #8
v8only
v8only's Avatar
Send a message via MSN to v8only
go to paperformance.com
order their wire with the fuse. it's a 4 guage wire with a 200 amp fuse in the middle of it. I believe your solonoid and battery are on opposite sides of each other, so order the longer wire.
That goes from the post on the back of the alt to the batt side of the starter relay. The other two wires are simple. Wire per the diagram. One of the small wires goes to the same batt side of the starter relay, the other goes to a key on switched 12v source...that's it.
You may need to clearance the alt bracket to make it fit. you'll know if you do when you try and bolt it up.
__________________
Jeremy
-66 Mustang, bench seat car,8.8,t5,crate roller 5.0
-1990 Bronco, 5.8 roller/AOD swap in progress, 4" rancho lift, 33's
v8only is offline   Reply With Quote
Old 05-18-2009, 07:17 AM   #9
85_SS_302_Coupe
Well now i feel like a jackass because i can't trace the wires up into my harness far enough to get to the OEM wires because i've taped the hell out of it and really don't wanna cut it all open.
But, i will talk to my buddy who did the wiring for me and i'm sure he can help out some. I just don't know jack about wiring.
__________________
-EVIL SSP-
The Stang
The CVPI
-David
Old 05-18-2009, 08:44 AM   #10
Marz
Nuts
Marz's Avatar
Send a message via AIM to Marz Send a message via MSN to Marz Send a message via Yahoo to Marz
Alt, Battery, starter, and starter relay are all on the passenger side for the 85 and under 5.0L cars.
__________________
Marz is offline   Reply With Quote
Old 05-18-2009, 11:50 AM   #11
darkwriter77
darkwriter77's Avatar
Send a message via Yahoo to darkwriter77
Been wondering about this, myself. I've done the 3G swap on a couple of '86+ cars and it's no problem, but the externally-regulated earlier Foxes are a mystery to me as far as the swap goes. I'm assuming you would probably have to snag the stock alternator plug off a junkyard car or get one (if they sell them) from the electrical connector section of someplace like Autozone (y'know, where they have replacement headlamp plugs n' such). Then you'd splice into and extend the wires that normally would go into your external regulator bolted onto the fender and run those over to the plug going into the 3G alternator ... but I haven't a clue which wires get spliced into which wires.
__________________
1986 GMC S-15 ext. cab 2.8 - DAILY BEATER.
1989 Mustang LX 5.0 notch - T-5, 4.10, alum. DS, KC clutch, Pro 5.0 shifter, O/R-X and Violator cat-back, A/C delete - WEEKEND TOY.
darkwriter77 is offline   Reply With Quote
Old 05-29-2009, 12:58 PM   #12
mustangpro
mustangpro's Avatar
I'm bumpin' this to the top to see if anybody else has some input. Picking up the 3G Monday.
__________________
65 Fastback 5.0
89 Notch 5.0
94 Cobra #819 5.0
Old 05-29-2009, 01:48 PM   #13
IEATLT1
Make sure you get the pigtail off the v-6 car make life alot easier.... I ran a 4 gauge wire from the alternator to the hot side of the starter noid jump the yellow wire from the pig tail over to where the 4 gauge connector bolts on and ran a key on wire to the other wire that excites the regulator
__________________
99 gt with 03 cobra swap and tko600
08 Focus (gotta have something nicer than a beater sometimes)
1999 Chevy Metro (gotta have a beater)
IEATLT1 is offline   Reply With Quote
Old 05-29-2009, 02:23 PM   #14
Ed-84gt
New User
Ed-84gt's Avatar
Guys check this site out alot of info The attachment is the wiring diagram for the 3g
http://fordfuelinjection.com
Also here is a link to the online auto manuals for all makes of cars it has the eletrical diagrams too ..
http://search.ebscohost.com/login.aspx?authtype=url,uid
Username : auto
Password :auto
__________________
1984 Turbo GT, 5.0 swap , T-5, 5 lug, 8.8 3.27 gears ,92 front brake upgrade,
Ed-84gt is offline   Reply With Quote
Old 05-29-2009, 05:56 PM   #15
lilred
FEP User
Quote:
Another option is to use a Variable speed controller for the fan.
http://store.summitracing.com/partde...5&autoview=sku
This is what I used on my car with a stock alt. w/underdrive pulley and taurus fan with no problems what so ever. I even bought a 3g alt to install but like I said haven't needed it.
lilred is offline   Reply With Quote
Old 05-29-2009, 09:14 PM   #16
Curtis
What about the electric choke? Isn't there a wire from the alternator to the choke?
__________________
85 GT vert
Curtis is offline   Reply With Quote
Old 05-30-2009, 12:24 PM   #17
darkwriter77
Quote:
That's pretty much just a 12v switchable line. You can run that from any 12-volt source that switches on with the ignition in "RUN."
__________________
Old 05-30-2009, 03:21 PM   #18
86GT5spdEVERETT
86GT5spdEVERETT's Avatar
Send a message via Yahoo to 86GT5spdEVERETT
i got my 3g out of a taurus, imagine that! same car as you got the fan out of.if its a 95 amp 3g it will fit right in if its a 130 light ones on the taurus is requres notching out the bracket to fit. heres a more direct link to the right page with pics of what needs to be notched. the v6 mustang 3g may not be a 130amp it may be 95 im not sure
http://fordfuelinjection.com/?p=75
__________________
86 w/87 motor,full cage, gutted interior,5 lug, H&R front springs, SVO A arms, jeggster subframe connectors, driveshaft loop, 2007 mustang bullitts, 25th anniversary dash, 87+ qrtrs....
96 honda civic 4 door
01 suzuki sv650s v twin crotchrocket
86GT5spdEVERETT is offline   Reply With Quote
Old 05-30-2009, 04:39 PM   #19
darkwriter77
The '94-'95 Mustang alternators are 130-amp according to parts store listings.
http://www.autozone.com/autozone/cat...065&questions=[]
__________________
Old 05-31-2009, 04:35 AM   #20
85 Speedfreak
85 Speedfreak's Avatar
Username : auto
Password :auto
That site is very informative.nice find!
85 Speedfreak is offline   Reply With Quote
Old 05-31-2009, 11:27 AM   #21
v8only
v8only's Avatar
my 90 3.0 taurus alt was a 130 amp...though I've heard many were actually less.
I hooked up my 3g plain and simple to my 66, and it's not going to be any different on a 4 eyed carb'd car.
Hook up the 4 guage fat cable to the batt side of the starter solonoid, and the other end to the post on the ALT.
This leaves 2 wires, skinny ones..if you took the junkyard harness. If not, paperformance has the plug for the alt.
one wire goes to the batt side of the starter relay, and the other gets a 12v key on source THAT"S IT!! The online diagrams will tell you which wire is which
if you're unsure where a 12v key on source is, run a wire from the radio power wire into the engine bay
__________________
Jeremy
Old 05-31-2009, 12:48 PM   #22
darkwriter77
Instead of running the one wire to the battery side of the starter relay, wouldn't it be easier just to run it to the 4-gauge post on the back of the alternator, since that cable also connects to the battery side of the solenoid?
__________________
Old 05-31-2009, 01:17 PM   #23
v8only
v8only's Avatar
DOH! You got me..typo...I did mean that I ran it between the alt and relay..NOT the starter
__________________
Jeremy
Reply
Tags
3g, alternator wiring, update charging
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
