Four Eyed Forums
Go Back   Four Eyed Forums > Tech > Race Tech and Dyno
Reply
Thread Tools Display Modes
Old 03-29-2009, 12:25 PM   #1
79notchback
79notchback's Avatar
79notchback is on a distinguished road
Default 1/4 mile first timer
I finally ran my car at the track yesterday, I have alot to improve in my driving and rearend. I did the one wheel pill through first and second gear the first time and ran 14.8 and the second time i tried to feather the clutch and ease on out of the gate. I ran 12.9 at 109.20 60ft 2.13 330 at 5.64 1/8 8.44 at 87.06 100ft 10.86 my question is how much would a new posi trac and a good set of drag radials help? and should i change my gears I currently have 3.55s and was at 5500 rpms in third gear through the end.
79notchback is offline   Reply With Quote
Old 03-29-2009, 12:39 PM   #2
martin0660
martin0660 is just really nicemartin0660 is just really nicemartin0660 is just really nicemartin0660 is just really nice
At least part of the problem with saying what you can run is the spinning. When you spin, you typically "trick up" the MPH. With a decent 60' (mid 1.7's) 109 mph will get you well into the bottom 12's.
I would leave the 3:55, and fix the t'lok for sure.
Tires are must if you want to ET. I am a believer that radials do not blong on a stick car, but others make them work. Consider a set of 26-10.50-15 ET Streets (biased) on a set of 10 holes for track use and have all the traction you will need. If this is as far as you plan to go (not bit by the bug), look into a set of MT ET Street radials.
I would suspect with traction you have an easy 12.50 at 106-107 combo. If it hooks and still MPH's it will run low 12's.
Bob Myers
martin0660 is offline   Reply With Quote
Old 03-29-2009, 01:24 PM   #3
KANARMAN
FEP User
KANARMAN's Avatar
KANARMAN is on a distinguished road
I think you shoud run 12 lbs or pressure in the rear drag tires roll back into the water pull forward just past rhe puddle do a brake torque lill smoke let off the brake wile moving forward. Get to lhe line gring it up to 5 grandbring the clutch up to were iy wants to move second amber .He Gone.I say 12.60 and a win if You catch him sleeping
nice times.
KANARMAN is offline   Reply With Quote
Old 03-29-2009, 06:14 PM   #4
79notchback
Thanks for the input I forgot to say that I had junk street tires on the car and I am planning on a set of mt et streets just not sure how big to go. Thought about 410s for gears just not sure if it is worth it. and yeah the bug got me bad also thinking about a 100 shot.
Old 03-29-2009, 09:33 PM   #5
anthonydalrymple
anthonydalrymple's Avatar
anthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant futureanthonydalrymple has a brilliant future
Send a message via Yahoo to anthonydalrymple
Rear gear usually helps with the 60ft as well. I'm having 4.10's installed soon since I a)Barely shift into 4th gear before the finish line and 5) I'm only 60ft'in 1.70-1.76 with the current 3.73's. I use M\T 26"x10.5" ET Streets by the way. 4.10's will get me into the 1.60 range I want to be in IMHO.....
__________________
'89 5.0 5-speed 'vert; 75 mile a day daily commuter. 331, AFR185, RPMII intake, TKO600, Zex 100 shot, etc. slowly getting dialed in.... 1\8th=7.43@92.54mph, 1\4=11.67@117.05mph for now....
anthonydalrymple is offline   Reply With Quote
Old 03-29-2009, 10:02 PM   #6
KANARMAN
FEP User
KANARMAN's Avatar
410 is great for natural asperated in my opinion and your tail pipes should be at your victims door causing the natural urge to shift when you do whitch normaly causes him to short shift.But thats not if they are vetern racers then they allways race there car not yours. 410 rev high on the expressway unless you keep it at 45mph or so but they are great for the hole shot on a sticky tire. id say 355 on spray best of both ?
get a wet kit with a rpm window switch abd a second feul pressure regulator. second gear comes real quick on the gun..
Old 03-29-2009, 11:26 PM   #7
895.0
895.0's Avatar
895.0 is a splendid one to behold895.0 is a splendid one to behold895.0 is a splendid one to behold895.0 is a splendid one to behold895.0 is a splendid one to behold895.0 is a splendid one to behold895.0 is a splendid one to behold895.0 is a splendid one to behold
Quote:
what part of texas are you from
__________________
19 year old owner of oreo five o's
1989 Ford Mustang GT- Black, FR-500's, P headed 302
1985 Ford Mustang LX T-Top White ex 4 cyl car
1983 Ford Mustang GT T-Top Black 351 with nitrous
895.0 is offline   Reply With Quote
Old 03-30-2009, 06:51 AM   #8
79notchback
I live in southeast texas near Beaumont. I am looking at getting the track lock fixed and a set of Mt et streets maybe some porting on the heads if its worth it, costs V/s results, they are AFR 185s.
Old 03-30-2009, 02:45 PM   #9
93MUSTANK
93MUSTANK's Avatar
93MUSTANK is on a distinguished road
Whats the combo??????????
__________________
OOTB TW heads , AFM B4 cam , Systemax , 4.30's
2900w/ driver
Best 1/4..... 11.51 @116 mph...1.52 60ft...1933 D/A
Need a cage to go faster.
93MUSTANK is offline   Reply With Quote
Old 03-30-2009, 04:35 PM   #10
79notchback
Its a 347 stroker motor stock block girdled, all forged internals H beam, 1.6 7/16 stud roller rockers 86-95 5.0 roller lifters, eagle rotating kit 4.030 bore x 3.400 stroke .030" overbore 5.400 rod length -6.5cc flattop pistons and AFR 185s 61cc no egr or air pump springs upgraded to 8015s valves upgraded .50l rev not sure what that means 6350 5/16” .80 wall push rods Victor Jr intake and prosystems 780 db, Comp cam Intake 565 Exhaust 574, .006tappet lift 282 and 290, Long tube headers not sure what kind H Pipe 2 1/2 inch mandral bent with 2 chamber flow masters MSD 6a ignition system. I was told 10.6 to 1 but looking at the paper work it looks like 10.2 to 1 on compression. This is backed by a wcT-5 thats been beefed up, 8.8 with 3.55's and positrac. I hope this helps.
Old 03-30-2009, 08:03 PM   #11
78Z7
78Z7's Avatar
78Z7 has much to be proud of78Z7 has much to be proud of78Z7 has much to be proud of78Z7 has much to be proud of78Z7 has much to be proud of78Z7 has much to be proud of78Z7 has much to be proud of78Z7 has much to be proud of78Z7 has much to be proud of
Send a message via AIM to 78Z7
I have 4:10s in my car. I have a T5. It is not that bad on the highway if you keep it around 60-65. I kinda wish I had 3:73s. I am not planning on racing mine though. I might go up once or twice but thats about it.
__________________
1978 Mercury Zephyr Z7
1998 Ford F150
78Z7 is offline   Reply With Quote
Old 03-30-2009, 09:28 PM   #12
KANARMAN
FEP User
KANARMAN's Avatar
Quote:
yeah I had a 7.5 rear with 410 and it was hard to play on the highway
the stock block was screaming and I was waiting to break thats realy the only reason Iwouldnt recomend it but it is fun for quarter mile blasts.
now I have 327 it keeps pulling and saves fuel but I have a stock btm end
except for cam and a mild built top end
Old 03-31-2009, 12:35 AM   #13
ratedz
ratedz's Avatar
ratedz is on a distinguished road
He probably makes gobs of torque so those 3.55's might be an ideal gear for him. Looks to me like you need a few more timeslips to get a better idea of how consistent your true trap speed is.
Fixing the trac loc and putting on a pair of drag radials or slicks and the car will pick up quite a bit. A 2.13 60' is pretty bad, get it down to a 1.6 or better (suspension) and I think you'll be happy.
__________________
1986 Mustang GT
306 H/C/I C4
67mm Turbo
10.37@131
http://www.skilledit.com
ratedz is offline   Reply With Quote
Old 04-01-2009, 05:08 PM   #14
79notchback
Ok got a set of mt et street drag radials 275 60 15 today and will have them put on tomorrow and try and get the tloc looked at if time if not I ll be running it again saturday and see if I can improve. I let yall know thanks for all the help.
Old 04-01-2009, 09:02 PM   #15
KANARMAN
FEP User
KANARMAN's Avatar
this might help but it is a little ghetto.
put new brake pads on the front loosen up rear shoes a little put friction mod in the rear end the first time drive around the water dump the clutch to clean off the tires get to the line dump it at 45-5500 rpm hope you hook and book if it feels squirlie stay in it keep the tires moving and dont worry about the crowd or the guy next to you and air down to 12lbs good luck
Old 04-02-2009, 06:40 AM   #16
Chris Wood
Chris Wood's Avatar
Chris Wood is a glorious beacon of lightChris Wood is a glorious beacon of lightChris Wood is a glorious beacon of lightChris Wood is a glorious beacon of lightChris Wood is a glorious beacon of lightChris Wood is a glorious beacon of light
12.9 @ 109 is not shabby at all, but you are giving up lots in the first 100 feet or so. I would (I did) throw in an 8.8 with 4.10 and some aftermarket lower control arms (Steeda, SSM, MM, etc), and a good drag tire. Depending on your choice, you could throw some drag radials on race only wheels for the track or drive around on 'em.
I ran my BFG Drag radials on the street some but I just didn't like the way they felt on the street (I like the curves too). Matter of fact I remember not liking the way they felt at the big end of the track either--wobble-wobble!
I was using a 235/60/15 (26" tall) tire with a Tremec 3550 tranny and in 4th gear at the 1/4 mile I was spinning 5,800--6,000 RPM.
I run 4.10s, and while I don't drive my car everyday, I do drive it on the highway (freeway @ 80 MPH), they are fun. Driving on the freeway at 80 MPH, in od with a 27" tire, equates to about 2700-2800 RPM, right in my cams sweet spot. My thinking is: why do I need the gear to run 150 MPH for extended periods?
__________________
'80 Merc Capri RS--306, TFS heads, MSD, Lunati, Tremec, 4.10s etc., etc.// '94 Lightning-#2252 KILLED in action 11-23-09 missed terribly // '10 Ford F-150 Crew Cab Lariat-wife's //02 Toyota Taco pre runner-now my DD
Chris Wood is offline   Reply With Quote
Old 04-02-2009, 03:38 PM   #17
KANARMAN
FEP User
KANARMAN's Avatar
I was using a 235/60/15 (20" tall) tire with a Tremec 3550 tranny and in 4th gear at the 1/4 mile I was spinning 5,800--6,000 RPM.
I agree with you can stuff a taller tire in there and do 80 mph but dont do it on a drag slick or et street unless you use a drag radial.Bfg,Nitto,M/T ect..
or you will be all over the place like you said about the top end you run out of power to keep them moving if that makes sense? I would get a set af rims to use atathe track with the tires.If you get cought in the rain or a puddle of water you will have to clean your shorts
I only hit 130 acording to gps in my car once after work on a back road with the t tops off and it was in the top of fourth gear it gets spooky with 90-10 and moroso trick springs
Old 04-02-2009, 04:11 PM   #18
badasspony
badasspony's Avatar
badasspony is on a distinguished road
That doesnt sound bad at all to me, get the 60s down and it will be much better.
badasspony is offline   Reply With Quote
Old 04-02-2009, 05:26 PM   #19
86nu
86nu's Avatar
86nu has a spectacular aura about86nu has a spectacular aura about
Send a message via AIM to 86nu Send a message via Yahoo to 86nu
if the car hooks and you keep 109 mph that will get you 12.2 range.
You might want to upgrade if you havent the rear control arms, and at the track undo the front sway bar.
__________________
86lx coupe
351w.....its just a truck motor
captain cave man racing!!!
faster than your first sexual experience
86nu is offline   Reply With Quote
Old 04-04-2009, 10:40 AM   #20
79notchback
I put on a set of mt et street drag radials yesterday, the tloc is still out but I am going to the track today anyway and see if it gets better plus I just need more time in the seat. 275 60 15 wish I would have went with 50 series this are 28 inch and its a little tight I had to roll the lip to make sure they want hit when pulling in the driveway but they look like they will be allright. I know i need the rearend fixed but I am looking for a third member with 373 and detroit locker right now. I called a couple of shops around here and they said about 800 dollars to fix it and It looks like i can get the third member with the gears allready for about the same. Ill let you know how i do today. I allready have aftermarket tublar upper and lowers with spherical bushings and lakewood 50/50s on now. I pretty sure it was the multi mile junk tires that where on the car.
Old 04-04-2009, 11:26 AM   #21
KANARMAN
FEP User
KANARMAN's Avatar
I say 1.8 12.51 @ 107 and a huge smile and a trip to to the local n.o.s drug dealer
good luck.
Old 04-04-2009, 12:55 PM   #22
86_Notch
86_Notch's Avatar
86_Notch is just really nice86_Notch is just really nice86_Notch is just really nice86_Notch is just really nice86_Notch is just really nice
i think the 355s are not enough gear, especially with your tire choice. you bought a taller drag radial which effectively reduces your gear ratio. a set of 373s or 410s will really wake up your combination.
__________________
" Spending money I don't have......... on things I don't need......... to impress people I don't know. "
http://www.youtube.com/v/HcD354133Ac
http://www.youtube.com/v/rmPPnfHZ9WA
86_Notch is offline   Reply With Quote
Old 04-04-2009, 05:53 PM   #23
crimsoncat66
crimsoncat66's Avatar
crimsoncat66 is a splendid one to beholdcrimsoncat66 is a splendid one to beholdcrimsoncat66 is a splendid one to beholdcrimsoncat66 is a splendid one to beholdcrimsoncat66 is a splendid one to beholdcrimsoncat66 is a splendid one to beholdcrimsoncat66 is a splendid one to behold
Yeah 355's wont be enough for the track, go with the 410's!
__________________
1983 Mercury Capri Crimson Cat 5.0 4 speed t tops
1986 Mercury Capri GS 5.0 5 speed
4.10 gears, aluminum driveshaft, flowmaster cat back, fms headers, pro 5.0 shifter, tokico suspension, o/r h-pipe
1990 Ford Mustang notch 5.0 5 speed
pro 5.0 shifter, aluminum driveshaft, 3.73 rear, ud pulleys, prothane mounts, mac headers, flowmaster cat back, o/r h-pipe, lowered
1971 IH Scout 800b all original 232 thrift six 3 speed
1992 Honda Civic VX 1.5 vtecE 5 spd
2001 Honda Insight Hybrid.. Best ave. 87.1 mpg!!!!!
crimsoncat66 is offline   Reply With Quote
Old 04-11-2009, 03:54 AM   #24
79notchback
Ok ran it this weekend but didnt get a good time only ran it twice and both times I missed second gear Its coming fast now that I can actually try and launch the car. Ill try and get more seat time and post some times later.
Old 04-22-2009, 10:20 PM   #25
Dave88GT
New User
Dave88GT's Avatar
Dave88GT is on a distinguished road
you really want traction, swap your front springs to the 4 cylinder front spring. it will help transfer the weight from the front to the rear. thats the thing with foxes you put any real power to the wheels and they just spin!
Dave88GT is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
