Ever since I got my SVO running and driving I've been chasing down noises and vibrations from every part of the car. Things kept getting better and better and I was now down to the final culprit being the rear axle. Some time in the cars past a set of 4.11 gears were swapped in. By the time I got the car the installation of the gear set was evidently flawed because the rear axle had a very pronounced whine starting at 40 mph, and an unnerving rumble during high speed deceleration. Fixing the rear meant new gears, bearings, and installation. I was easily looking at $500. I decided to go another route.
I found a 1987 Thunderbird Turbo coupe in a local junk yard and managed to get the rear axle(minus brakes and axle shafts) for $100. 3.55 gears, traction lock 8.8". I brought it home and installed new axle bearings and seals just to be safe. Bought the proper 8.8" rear brake hose, gear oil, traction lock additive, upper bushings, and I even went so far as to pick up some new brake calipers from NAPA. I had rebuilt the original calipers almost two years ago with a seal kit. I took my time and did everything I could but they didnt seem to last. I could have rebuilt them again but I doubt I'd of had any better luck. A three year warranty and they came with all the new hardware you could ask for. New slider pins and bushings, ant-rattle clips, copper washers, slider pin grease, and even a new bolt for the e-brake arm. $62 ea and the core was $82 ea. The first time I ever had the core cost more than the part.
I needed to remove the Turbo Coupe brake brackets from the axle housing. Did that with grinder and they came off very easily.
After cleaning it up more I then painted the housing with some POR 15 chassis black paint.
The quad shock brackets on the turbo coupe housing are taller than the mustang ones so I marked and made the holes to match. I ran into an issue with the quad shocks but I'll explain that at the end.
After that, swapping everything from the old axle to the 8.8 was straightforward.
Up and into the car.
It all went quite well. Right up to the point where I lowered the car to the ground. When I did that the car was riding high in the rear to the point of there being 3-4" of clearance room the top of the tire to the fender. The suspension would not compress any more. Turned out to be the quad shocks were at their short limit. Meaning the suspension was effectively locked against the quad shocks as they wouldn't compress any more.
I measured the quad shock brackets and transferred over the measurements from my original axle. I don't think I did anything wrong in the way I measured the holes in relation to the difference of the way the brackets are mounted to the axle. I removed the quad shocks for now but am wondering what can be done to make it work. I'll need to play with it at another time.
But that issue aside.... On the road the car drives great. With the proper speedometer gear installed the speedo is accurate to 2mph according to my GPS. There is no more noise coming from the rear end. Hooray! It'll take a little getting used the gearing change. Its not a big difference(4.11 to 3.55) but behind the 2.3 its a bigger deal than if it were behind a 5.0. I'll see how it does in the mileage department too during the next tank of gas. It should start paying for itself. For a total outlay of $150(minus calipers) it was a no brainer swap vs new gears in the 7.5" rear.
