Page 1 of 7 123 ... LastLast
Results 1 to 25 of 165
    Jan 2004
    Arlington Washington
    Default My SVO Motor Mayhem
    ****UPDATED.... Motor Mayhem Take 2 can be found on page 6 towards the bottom.*****
    Well since I have been MIA lately, I figured it was time to share why. My svo developed a rod nock shortly after buying it, so I drove it until I could here it at idel. Thats when I parked it for a few months until I had time to pull the motor and inspect it. Well the time came in the last week of june. Chalky came up and helped dad and I pull the little beast out. And all I can say is that chalk was invaluable for the pull and tear down! Once the motor was out we found a number of things that has lead to a full rebuild. Right off the bat we found that the block was a replacement with a factory rebuilt head on it. The turbo was in decent shape with the blades in perfect shape, but the bearings were gone. Not bad considering its most likely the original. Got the head off and it looked good too, but it will need valve stem seals. The bottem end was another story. There was good evidence of abuse, overheating, and detination present. So to find out more I tore it all the way down and took it to the machine shop.
    The machine shop results came back that it would need an overbore, crank polished, a valve job, new cam and rockers. So with info in hand I ordered new .020 pistions, rings, rubber water lines, aux cam bearings, gaskets, turbo feed line, and a 180 fan control switch from MotionDynamics. From Forced4, I ordered there CAI with bypass kit, there motocraft tune up kit, PCV valve, fuel filter, intercooler hose kit, and a acufab FPR just so I can play with some greater boost. The machine shop is getting the bearings for the crank, cam bearings, oil pump, an 86 camshaft, and the rockers. I also sent my turbo out to evergreen turbo for a rebuild. It just showed up today and charlie did a sweet job on the thing.
    Enough yapping its time for some pics.......
    Keep this sad image in your head, because I am cleaning it way up.
    Good old rust under the battery box....
    Stripped down far enough to pull it....
    Group shots
    With the trans and intake off, chalky is preparing himself to crack this thing open...
    Heads off, but the cam dosen't turn smooth... Uh Ho
    One of main caps was on backwards, and the crank didn't turn smooth until all rods were out.
    Almost all the bearings looked like this.
    And one bare empty block.
    Oh ya heres one of dad, being dad!
    Thats it until I can take more pics off the camera.....
    1982 Capri RS 5.0L
    1985 SVO 2A & leather.
    Note to all, I normally only drink Dutch Bros coffee but there wasn't one close by. Besides, the girlfriend was buying and she prefers the 'buck.
    Glad to help Nelson, I love gettin ma hands dirty and can't wait to bolt it back together this coming weekend. Let me check to see if I've got an spare E6 exhaust manifold laying around and if so I'll port one out for you.
    Lastly, now that you know my detailing secrets, you better get to work if you want to have the nicest looking SVO engine at the BBQ this year
    Ausie, Aussie, Aussie
    Oi, Oi, Oi
    84 1C SVO "Blackie the Wonderbeater" (DECEASED!!!!)
    84 9L SVO T-TOP (under restoration)
    84 1C SVO T-TOP (Deceased)
    86 2R SVO (roller, future pro-tourer)
    Jan 2004
    If you want to take a crack at an e-6 go for it. I was going to take mine in and have the machine shop open outlet hole so its not D shaped buts thats it. I was also going to have him open the heads exhaust ports up to, but based on the numbers on svoca, I would only be taking an 1/8th inch off each port so I pased on it. Seams like they were already opened up once and the intake show definate signs of this. As for detailing, it will be kinda hoj pojjed due to the dead line. But at least the intercooler is almost done, the valve cover is coming along slowly, and I still need to take the intake apart and paint it. So the top half should look good, just don't look down.
    1982 Capri RS 5.0L
    FEP Senior Member captnet's Avatar
    Jun 2007
    Quakertown, Pennsylvania
    Good to see your working on the car Schoolboy! I remember you talking about it a while back I bet it will turn out real nice.
    85 Capri 5.0L Sport Package (purchased new)
    03 Jeep Grand Cherokee 4.0L Laredo 4x4
    -- The simple believeth every word: but the prudent man looketh well to his going.
    FEP Power Member RichV's Avatar
    Aug 2003
    Elizabeth, Colorado
    Sweet! That's what I get to do this off-season. Mine runs fine, I just need to detail it and reseal the motor.
    OT, does anyone know if a decent set of poly mounts exist for an SVO? And if I get some, do the hydraulic dampners need to be re-installed?
    85 SVO
    94 GT CMC#71
    65 Fastback
    Jan 2004
    Quote Originally Posted by captnet View Post
    I hope so, but at this point I will be happy with running. I have been sick today, so I didn't make any progress what so ever.
    Quote Originally Posted by RichV View Post
    For the poly mounts look up motionDynamics, I know the have them, but you will need to call and talk to someone.
    1982 Capri RS 5.0L
    Sep 2005
    Pensacola, Fl
    Looks like my 84GT Turbo right now...only I am doing mine because I am sadistic, not because I had too!!
    FEP Super Member anthonydalrymple's Avatar
    Nov 2004
    Salt Lake City, Utah
    Looking good..... Progress, though slow is progress nonetheless!
    '89 5.0 5-speed 'vert, seeing rust for the 1st time in it's life as well as 4,500+ elevation....
    Jan 2004
    5 Days to go before I want to fire the thing up, let the count down begin.... Now for more pictures!
    Crank after getting cleaned, and wear marks from the dirty build up...
    Here is the block all cleaned up.
    Casting marks, and the select fit order for the original pistions.
    This will be the last time he volinters to work on my car for 5 bucks....
    All clean, well its better anyways.
    How do you stop rust, smother it until I can aford to fix it correctly.
    Cleaned up and painted x-brace.
    Pistions.... Woop Woop!!!
    Intercool is almost done!
    Pain in the ass valve cover. The wrinkle finsh will not give up.
    1982 Capri RS 5.0L
    Sep 2005
    Pensacola, Fl
    Looking good! Did you use Aircraft stripper from Kleen-Strip to do the valve cover?
    FEP Power Member 82HATCH's Avatar
    Sep 2003
    memphis michigan
    Cool project!
    Earl Ingstad evlgt85's Avatar
    May 2002
    Phoenix, AZ
    Blog Entries
    4
    Those are some great pics. Looks like you guys have fun in the face of mechanical adversity. Very cool.
    I think the one of Neil needs a caption pretty badly, though.
    Nov 2004
    Underhood Neil is watching you!
    Jan 2004
    Quote Originally Posted by 86GT2go View Post
    Its aircraft stripper for sure sold by shucks...
    Quote Originally Posted by evlgt85 View Post
    I feel a contest might be in order...
    Quote Originally Posted by anthonydalrymple View Post
    Oh but thats not dad. That is someone you will meat in near futre...
    1982 Capri RS 5.0L
    SchoolBoy, Good work so far.. But seriously, Replace the Rag Joint now while you can get to it easily. Having just changed one with the engine in place, it is a horrible pain in the rear!
    Other than that, Keep it up!
    It puts the ATF in the T5... IT DOES AS IT'S TOLD!!!!!
    Jan 2004
    We will check it out, but it felt very tight last time I drove it.
    1982 Capri RS 5.0L
    haha they fail when you least suspect it...
    FEP Super Member 82mustang's Avatar
    Aug 2006
    Aberdeen, Washington (The State)
    lookin good nelson, looks like at least 2 peojects will be done in time for the BBQ, i'm really excited for it
    86' Coupe Street/Strip Never Ending Project-351w, 4 Wheel Disk, WC T5, etc...
    Link to my car Pics:
    http://smg.photobucket.com/albums/v414/hyper7pbs/
    Mar 2004
    North of Seattle, near the "Four-Eye-Field-of-Dreams"
    All you guys are lucky, I have to LIVE with these 2 goofballs....arrrgggggg.
    Dad
    Check out the Northwest "4-Eye" BBQ here >>> WWW.NWFOUREYEBBQ.COM
    foureyebbq@hotmail.com (to be put on the BBQ list )
    Lots of pics of my ride for your viewing pleasure....
    http://www.cardomain.com/ride/2052657/1
    FEP Power Member stockhatch's Avatar
    Feb 2006
    Southport NC
    Lookin' good fellers! If you want to take the paint off that valve cover, use some permatex gasket remover. It comes in a spray can and sucks to remove gaskets, but takes skin and paint off very nicely.
    87 Soarer//1jzgte//r154//bw 83-75
    Feb 2005
    Sunnyvale, Ca.
    I is under yer hood pedalin' fast.
    Rob
    1984 GT Convertible: Born November 1983 so it has slapper bars and no fog lights. Has DSO 89 (Transportation Services) and later sold to a Ford VP of Finance in Palo Alto, CA. Medium Canyon Red Exterior, Charcoal Interior, 5.0, 5-speed, power windows and doors, and 85k miles.
    http://s257.photobucket.com/albums/h...ics/?start=all
    Jan 2004
    Ok so there is no way the svo will be under it own power for the BBQ. It will most likely be next month before its ready. I simply have to much money into this to rush it along. So I did make some more progress with the valve cover. I got it fully stripped, sanded the area's I wanted to polish up, and polished it. What a long tedious process that was. I found that the cover even had a grain to it. It would clean up better sanding in one direction vs another, most weird. after I cleaned that all up, I washed it with dawn dish soap to get all the crap off. To mask it I used green masking tape and a hobbie knife. The super fine areas like the ford oval and small lettering was cover with a film. Its a watery substance that forms a protective film when it dries. It worked ok for what I was doing. I painted the valve cover in low gloss black dupla color 500 degree paint. If I was do it all over, I would take the valve cover, intercooler, intake, exhaust manifold and have them all blasted then powder coated, end of story. My way works ok, but it a ton of work for an end product that scratch's way easy! Now for the pics.....
    Here is the cover, striped and polished.
    Here is how it looked masked and filmed.
    Fresh from paint, almost looks grey in these pics...
    I removed the masking tape only because the paint was still very fresh.
    All done, watcha think....
    Dad went nutz cleaning the garage, this is the after math.
    So much crap for a 4 banger....
    1982 Capri RS 5.0L
    Is the valve cover getting a coat of clear?
    Jan 2004
    Not at this time. Should it?
    1982 Capri RS 5.0L
    All up to you. Just that any exposed raw aluminum that gets wet may get ugly.
