#51 |
Thanks this thread i already have reservations to do this come spring.
__________________
Neal |
#52 |
thats awesome. I remember my uncle built a car roller when I was a little kid. He would use it at the junkyards. They were metal and fairly small, they bolted to the wheel mounting studs. Pretty simple, jack up car, take off wheels and bolt on the things and then use the jack to jack up the other side untill it would roll on its own! I never had any pics and it was home made but I think it would be doable and could be fairly cheap, not as cheap as the wood ones though.
#53 |
#54 |
I made a quick video with our new camera. Cheesy I know, but it shows how easy it is to roll.
http://www.youtube.com/watch?v=lSfZakPnqxM |
#55 |
Great Vid i started my rotissery tonight and am baseing it off yours but modified to have casters as to move it around while on its side! Dave
#56 |
If im reading this right the end of the 2x6 on the rear is 14.5" from the outside bolt hole on the rear bumper post?And the front 2x6 is 19.5" from out side holes on the front post?
photobucket [/QUOTE]
#57 |
Banned
That is just too cool!
#58 |
It looks to me now that your 93 has different mounting holes on the front bumper posts. In the middle on top and bottom and sides where as my 81 the holes are in all 4 corners! Am i correct?
#59 |
New User
Alright, I KNOW this is an old thread, but I just have to say BRAVO! That's so cool. I was doing a Google search to find the least expensive twirler that I could find. I found this thread by accident.
I will be building one of these for sure. I just wanted to say thanks for the idea. I also figured it wouldn't hurt to bring it to the top for others who haven't seen it. Very cool! Never would've thought of it on my own. This just made my day! |
#60 |
I agree. American ingenuity is alive and doing very well. Even my wife and daughters (20 and 16) thought this was cool. I'm subscribing to keep the info for later use.
__________________
Craig "IDMooseMan" Peters 1979 Mustang Ghia Notchback, 2.3L, Holley 5200, 4-spd, 3.08:1 non-locking 7.5" diff, A/C, PS, PB, AM/FM/8-Track, Sunroof, Rear Defroster American Legion, NAHC Life Member, NAFC Member, USAF SSgt 1983 - 1992 To those that serve and have served, "Thank You", to those that haven't, "You're Welcome" Buyer/Seller Experience Link Build Thread |
#61 |
FEP User
wow, way too cool!!!!
the members on this site is what makes our hobby so much fun! way to take an intimidating job for a novice and turn it into a cheap and easy no brainer!! |
#62 |
I did the exact same thing
All in all my car is painted and perfect underneath, Now my neighbor is using the Wood rotisserie! |
#63 |
What would I need to ADD to this for my T-top? Is my shell weak enough to require more bracing before I do something like this?
#64 | |
Quote:
IMHO you have a couple of options, you can make door bars that go from the door hinge areas to the door striker. Mine were metal since I did several Mustangs/Capris and reused them several times. Mine were 2 bars, one went from each hinge to the striker and were welded together at the striker mount. This triangulates the opening and really stiffens it up. The other option that I usually did in addition to the door bars on T-top and convertibles was a cross brace inside the cockpit area. Many times I would go from the seat belt shoulder mount to the opposite side lower seat belt mount and vice versa from the other side. This makes a large X brace that then I bolted together where they cross or intersect. Obviously this has to be modified a bit for a convertible, but your's is a T-top. Hope that helps a bit. Feel free to PM me if you need or want more information. Good Luck! Trey
__________________
"I never drive faster than I can see, besides it's all in the reflexes!" Mustangs Past: Too many to remember! Current Mustangs: 1969 Mach 1 1979 Pace Car now 5.0/5 speed 1982 GT Awaiting Restoration 1982 GT Race Car candidate 1984 SVO Awaiting Restoration 1986 Coupe 4cyl/4 speed? 1986 GT Wrecked by PO, but still want to save! 1991 GT Awaiting new drivetrain Current Capris: 1982 Capri Roller 1984 Capri (Now Sitting in CO Finally!) 1985 Capri RS Roller (Still in TX) 1983-84 Gloy Racing Trans Am/IMSA Body Parts |
#65 |
Trey, do you have any pics of the extra bracing you use?
__________________
Dave If common sense was common wouldn't it just be sense? 1983 Capri T top 5.0 efi aod 1983 Capri RS Turbo 1981 Black Magic 6.6 c6 93 F-250 351 5sp 4x4 |
#66 |
I actually did add some casters to mine to roll it in and out of the shop. I will post better pics of the caster setup when I get them off the cell phone. Had to show you the bedliner too....its just too awesome looking!!
#67 |
I will see if I can find any pictures of the set up on a Mustang. I do have the door braces and could possibly take a picture of them by themselves too. Just have to dig them out of storage. Let me see what I can find.
Trey
__________________
#68 | |
Quote:
Trey
__________________
#69 |
Yep. I already made sure of the bolt holes having plugs. Really the only bolt holes left in the bottom after I shaved and smoothed everything was the two seat belt holes in the tranny tunnel, but I already thread chased them. I shaved the rear seat area belt holes and mounts. This car wont ever go back to stock!! lol
#70 | |
Ive been thinking about using the bed liner on my coupe, looks really nice.
did you spray it on or roll it? Quote:
#71 |
I sprayed it on...comes in a kit. Its called UPOL Raptor Bedliner and its 4 liters and it comes with the spraygun....by FAR the easiest DIY kit out there....and the best looking DIY kit. It looks very close to my buddies truckbed done with Line X. I am very happy with it. Wish I had better pics of the whole bottom. But the ones I took on my cell phone were before it fully cured and the lighting kinda sucked. I am loading some more pics of the rotisserie now. I only had $60 in the whole thing....casters and all. And those casters are PRICEY at TSC. Thank God I found them for alot cheaper than TSC at another store.
#72 | |
Perfect thanks! Glad to see you starting to make progress on yours again
Quote:
#73 |
Thanks buddy. I am trying to make it happen. Money and motivation are hard to come by sometimes along the way. Here are some more pics.
![]() ![]() And this cant be stressed enough...I almost had the damn thing flip over onto the race trailer trying to pull it back in the shop. One of the swivel casters broke out and off of the wood and slammed the thing down onto the wooden A-frame. I added some steel plates on both sides of the wooden frame (sandwiching the wooden frame basically) that I welded to the casters mount plate. Then I drilled holes and bolted through those plates and the wooden frame...so that wouldn't happen again as I pulled it over the uneven concrete slabs in the back of my shop. I circled the areas I added these plates. ![]()
#74 |
It's good to see people actually use their brains. I really like clever ideas.
| Tags |
| rotisserie |
| Thread Tools | |
| Display Modes | |
