#1 |
So I've found my LSC rear brakes may be too big when I run PBR brakes up front. The brake bias will be too much in the rear, even with a proportioning valve cranked to the rear.
Does anyone know if I can swap the 99+ PBR calipers on the LSC rear end? I'm sure the brackets are different, how about the spacing for the rotor on the LSC axles? Or should I just try to find a 99+ rear end? I don't care about them being wider like the LSC. Thanks! |
#2 |
I dont see how it would be an issue. LSCs and SVOs had 73mm front calipers, so the 38mm twin piston PBRs offer more clamping force than the front brakes originally on the cars that came with these discs out back.
I'm not trying to slap you in the face, sorry if it seems like I am, but are you sure you're turning the knob the right way on the prob valve? I'm putting the same brakes on my car...
__________________
-Zach '81 Zephyr Sedan: Empty shell. Piles of parts. Finally found a garage to rent |
#3 | |||
I dont have the brakes installed yet. Here are some posts I got from a MM rep:
Quote:
Quote:
Quote:
#4 |
Well the MM guy can use his math, and I'll just try it. I do that a lot at work with the CNC press I run. They say it wont work and I do it anyway, most of the time it works.
My car wont see the street for a while, so if you dont try it I'll let you know how mine turns out, a few years from now, if I remember... My main reason for choosing the flipped lincoln rears was because of the number of posts I read where guys had to use spacers to get draglites or other 15" wheels to fit over cobra rear discs.
__________________
#6 |
Yeah, that makes a lot of difference.
__________________
#7 |
Sounds like a complete new rear is probably the best choice if you're not concerned with the additional diameter. Very interesting read as i'm pondering additional brake upgrades myself.
__________________
'83 Hatch - 5-lug with PBRs, Eibach Sportlines, Tokico Blues, MM CC plates, 8.8" |
#8 |
Well now some people are saying not to gut the stock proportioning valve and run a aftermarket one also. This will give the rear less pressure.
Who knows, I'll just throw it in there and see what happens like Zephyr said. |
#9 |
Damn, so the jist of the story is that Lincoln rear brakes are too large to use even with Cobra fronts? That was my plan until now...
__________________
The Capri is gone, time to get going on the Maverick! |
#10 |
FEP User
The brakes you have will work, you just need to gut the pv and get an ajustable one. There are several people on this site running similar brakes, I am in the process of going to cobra fronts and mark 7 rears
__________________
86 GT, Xplorer intake, full BBK exhaust with dumps, Mass air converstion, e cam, Parting together SN95 brake kit! |
#11 |
I had PBRs up front and the stock SVO/LSC calipers out back and the pedal felt hard and it took alot of force to stop. I went with Cobras all around and will never go back.
__________________
84 SVO 81 AMC Eagle |
#12 | |
Quote:
What bootser/MC were you running?
__________________
#13 |
I was running the SVO master and booster. When I went with the Cobras I used a Towncar MC and SN95 booster.
__________________
#14 |
Sorry to come to the party late, but I've been thinking about this same problem myself. Why couldn't you just leave the stock proportioning valve alone? Wouldn't it then direct most of the fluid to the front and less to the rear as if it were still operating front discs and rear drums?
I have a whole LSC disc brake rear and '94 spindles and brakes sitting around that I was going to use to convert to 5 lug until I heard about this problem myself. My thought was just to keep the stock proportioning valve. Does anyone know if this will work?
__________________
2R '85 GT 'vert - VIN code M fuel injected 5.0 HO The greatest discovery of my generation is that man can alter his life simply by altering his attitude of mind. - William James |
#15 |
drum brakes NEED a small amount of constant pressure to keep the wheel cylinder pistons from falling in and getting jammed in the wheel cylinder...but on drum brakes this isn't enough to engage the brakes so it's never a problem, swap out the drums for discs and you have a small amount of constant pressure on the pistons which directly push on the pads..dragging the brakes.
__________________
86' Coupe Street/Strip Never Ending Project-351w, 4 Wheel Disk, WC T5, etc... Link to my car Pics: http://smg.photobucket.com/albums/v414/hyper7pbs/ |
#16 |
I actually got all my parts from another car. It had a stock master and booster with the aforementioned SN95 stuff up front and the LSC rear out back. The brakes did NOT drag at all, however the pedal was practically to the floor, I'm guessing because the master cyl did not have sufficient volume. It was an '85 former 4cyl notchback.
__________________
#17 |
I'm just wondering because this was my plan as well. I just bought a lincoln rear and SN95 fronts.
Thanks, Matt |
#18 |
Not to be a dumd*&^, but what are PBR calipers? What mm are the pistons?
Thanks, Matt |
#19 |
The Decoder Guy
PBR International is a brake system manufacturer based in Australia. (They also have manufacturing in SC and TN.) They specialise in OEM braking systems.
PBR calipers have been OEM on Mustangs since '99...single piston front calipers on V6 and GT models, and dual piston on Cobra, Bullitt, etc.
__________________
'83 GT, '84 LTD LX, '85 LTD LX (parts car), '96 B2300 SE, '99 CVPI |
#20 |
V6/GT SN95s had single piston front calipers from 94-98, the 99+ front PBRs have dual 44.5 mm pistons.
__________________
#21 |
So did anyone except Rick do this with results?
Reading all the MM stuff has me a bit concerned now. I'm looking at the 13" upgrade for 2009 on my race car. My conclusion makes no sense. What I gather is that the stock SVO brakes, which I have currently (F+R), are not matched well with with the front 13" Cobra setup. The SVO rear brakes stop too hard for the Cobra 13" brakes, which then makes the front SVO brakes more effective?? So, my 73mm single piston caliper puts down more force than a twin piston 44.5mm (89mm total)???? I would think the Cobra fronts would grab harder than stock SVO fronts. Stock SVO brakes are decent, but nothing to write home about. They really have no more stopping power than the late Fox V8 brakes, maybe a little more bite, but not much.
__________________
85 SVO 89 Notch CMC#71 |
| Tags |
| brakes, calipers, pbr, pbr calipers |
| Thread Tools | |
| Display Modes | |
