#1 |
i just found a great set of 1980 tail lights at the wreckers.
i want to put them in my 86 because theres so much room between lenses and the license plate and i want to put my battery kill switch in there when the battey goes to the trunk. does anybody know if the screw in lights are the same in all mustangs back then?
__________________
1986 beige lx 5.0 conversion - 306ci. edelbrock 1.94 performer rpm aluminum heads, performer rpm airgap intake, performer rpm cam, roller rockers,moroso oil pan, edelbrock 600cfm carb, bbk shorties, offroad h-pipe, flowmaster 40 series mufflers 2.5 pipes, holley high flow fuel pump, T-5 tranny, 8.8 rear with 3.73 gears,aluminum rad, driveshaft loop, weld in sub-fram connectors, 5-bolt cragar SS wheels best run: 13.3 at 101.6mphhttp://www.youtube.com/jakesmustang1986 |
#2 | |
Quote:
#3 |
The Decoder Guy
Have to drill additional holes in the taillight panel (the metal frame that's part of the body that the taillights bolt to) and modify or change out the wiring.
#4 |
do you know whats involved in the changing the wiring?
__________________
#5 |
The Decoder Guy
Remove the interior trim panels that cover the taillight panel and trace the taillight wiring harness back (towards the front of the car) to the first plug/connector. As long as the '79-'82 taillight harness has the same plug and the same wiring arrangement, it'll swap right over. If it's not the same you're going to be in for some fun.
#6 |
i havent had mine appart but i would think there are 3 bulbs in each light assembly just like these other ones?
__________________
#7 |
The Decoder Guy
Yup, three each. But the function of the tailllamp, stoplamp, and turn signal is different for each.
#8 |
The bolt mounting pattern is different and for me the deal breaker is that the
cutout holes are different and the sealing will be affected. When I do this to my 86 I am seriously considering putting the taillight panel from an 82 on it. Radical I know but it would bother me. On the wiring I think all you have to do is lengthen or shorten some wires.
__________________
Current list o' cars 87 hatch california car 94 SHO Taurus DD 96 Aerostar FH 77 HighBoy with a BBF Memorable cars from my past 69 stang sports roof 302 GT RARE! 63 XL Galaxie loaded 75 Torino with a BBF 80 Capri coupe 82 stang hatch Turbo conversion car 82 Escort with a 2.3 85 'stang coupe with a 4.6L 4V Cobra motor 85 LTD with a 302 67 'stang coupe roller 61 Starliner Galaxie with a 428 SCJ 72 'stang sport roof |
#9 |
The Decoder Guy
Negatory on the wiring change being that simple.
Go look at the taillamp/stoplamp/turn signal arrangement and function of '79-'82 taillight wiring. Now go look at '83-'93 wiring. '79-'82 tails = TWO taillamps/stoplamps/turn signals '83-'93 tails = ONE taillamp/stoplamp and ONE turn signal In other words, the two '79-'82 bulbs work in unison as taillamps AND stoplamps AND turn signals, and the two '83-'93 bulbs don't (ONE is a taillamps and stoplamp and ONE is a turn signal). The "third" bulb is back-up/reverse. You have to modify the harness or change it. |
#10 |
so why cant i leave it and have one tail/stoplamp and one turn signal and one reverse light? 3 bulbs, 3 holes.. i dont see what the big deal is
__________________
#11 |
FoxChassis is right on this,
BUT, you can have perfectly functioning taillights by just lengthening some of the wires. I try to avoid splicing wires if I can. You could probably take the tape off and find enough play in the wiring to avoid straining the connections, and avoid extra splices.
__________________
Current list o' cars 87 hatch california car 94 SHO Taurus DD 96 Aerostar FH 77 HighBoy with a BBF Memorable cars from my past 69 stang sports roof 302 GT RARE! 63 XL Galaxie loaded 75 Torino with a BBF 80 Capri coupe 82 stang hatch Turbo conversion car 82 Escort with a 2.3 85 'stang coupe with a 4.6L 4V Cobra motor 85 LTD with a 302 67 'stang coupe roller 61 Starliner Galaxie with a 428 SCJ 72 'stang sport roof Last edited by Peganit2; 02-03-2008 at 12:24 PM. Reason: addendum |
#12 |
I have seen what you are talking about at the drag strip. It was an 88-93 with 1979-82 taillights and the kill switch was clearly visable. I didn't notice if the lights worked. It did look like a street car.
__________________
1980 Cobra Clone http://www.cardomain.com/ride/2364382 1981 Cobra (dust collector) http://www.cardomain.com/ride/2933624/1 2008 Ram 3500 Megacab http://www.cardomain.com/ride/3241506 |
#13 |
so maybe it won't function "exactly" like 80 lights but ill still have a backup light, a brake/running light, and a signal light... correct me if i'm wrong
__________________
#14 |
Cmon.. you've already done a 5.0 swap, don't be scared of a little wiring.
__________________
Marc aka tripice351. 84.5 GT-350 2.3T, 89 Vert 5.0, 54 F-250 390FE, and a few more.. Please click here to check out my parts for sale on eBay. |
#15 |
haha
it's not that i just want to keep it simple so that i can swap my 86 lights back if i ever wanted to
__________________
#16 |
Correct, you will have all the legal lights you need.
__________________
#17 |
I agree. I had never knew the 79-82 lights where like that. with three bulbs and only two(so to speak) functions. I think that would be better than stock 80 tail light setup. I'd like to have some LED panels made for my car to replace those three bulbs.
__________________
http://images.laughingman1.multiply.com/logo/4 Laviathans Cave Foxy Lady, vote for her His Life as a... |
#19 |
and I seen some led bulb replacments too. but I forgot what website. Not bulbs but a whole circuitboard that goes in each section.
__________________
#20 |
Just drill through the plate. You can take off the lever if you want but I've never gotten any grief over mine.
| Thread Tools | |
| Display Modes | |
