| View Poll Results: Do you have wipers on non-trailered car? | |||
| Yes |
19 | 70.37% |
| No |
8 | 29.63% |
| Voters: 27. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1 |
I'm contemplating deleting my wipers, motor, everything on the notch. The car wont be a DD but it will be driven to and from the track (autocross) and the occasional Stang meet.
Who runs no wipers with something like Rain-X? Comments?? Oh yeah, I'm in Florida. Last edited by KAILUAZ; 11-25-2007 at 05:49 PM. |
#2 | |
Wipers are always a good thing to have. If it was trailered and only for the things you mentioned I would say delete them.
__________________
-Kal "One man can make a difference." -Wilton Knight 85 Mustang GT T-Top The Wraith RIP -Shilo B. Dec.'09 Quote:
#3 |
I haven't messed with wipers in a while but can't you just delete the passenger side only? Then just remove the wiper arm on the driver's side at the track? Are you just doing it for weight reduction?
I don't think it would make much difference for just auto-x?
__________________
85 GT vert 1C 86 4E Capri 84 SVO Watkins Glen Pace Car 1E 85 SVO Hertz 4E 85.5 SVO 2R orig owner 85.5 SVO 2R Barrett-Jackson 86 SVO 7B 86 SVO 2A Comp Prep 86 SVO 1C T-Top 66 Fastback |
#4 |
Well, living in here sometime you just need wipers. Rain may come anytime, even when youre at the track.
__________________
1979 cobra 331+ t5+ 8.8" 354hp/492nm torq 1981 t-top "sold" 1976 gran torino 400 +c6 www.ford-freak.org |
#6 |
im going to delete mine but im just using the caps that you can buy at upr, getting them powdercoated black then carrying a set of wipers in the trunk just in case.
__________________
04 Lightning- Built motor, BTS tranny, Boosted Performance Built, PRO-DYNO tuned 86 LX- under construction |
#7 |
Some states require them , Oregon is one of those .
Don't have to have a windshield , but have to have the wipers , and they have to work !
__________________
clowns to the left of me , Jokers to the right |
#8 |
I rain-x'd the windshield but have yet to test it against the rain. I don't take it out in rain but have wondered what would happen if I got stuck in a downpour
__________________
87 T-Top 306 86 GT vert SOLD 68 Shelby GT-350 #999 86 Capri new project. FRED I NEED PARTS |
#9 |
New User
I deleted mine by using copper plumbing end caps for 1/2" copper pipe. if you pinch them ever so slightly with a pair of channel locks they slip on the splined posts with just a little resistance and then spray them semi gloss black to match the widow trim they'll pretty much disappear. If you aren't trailering the car then you can't say you won't get stuck in the rain. And rain-x won't keep other elements from smearing your view. Besides you'll just have a gaping hole in your cowl panel.
#10 |
In a downpour, the rain would run off lthe windshield like it runs off your hatch. STill whats the point of not having windshield wipers?
__________________
http://images.laughingman1.multiply.com/logo/4 Laviathans Cave Foxy Lady, vote for her His Life as a... |
#11 |
I deleted the wipers on my 94 and did the rain-x thing and let me tell you.....if it downpours the rain-x is useless unless you are going 40mph or faster. I'll keep mine.
__________________
83 GT Turbo 84 GT Turbo (on it's way) 84 RS Turbo (Rotter) 86 Capri (Project Green Bean) |
#12 |
I guess I should have explained the reason for my question a little better. I'm going to run a cowl induction setup inside the cowl itself. The air filter will be in the area where the passenger side arm is. The inner wiper rod mechanics need to be removed form the passenger side, thus leaving the driver side inoperative also.
#13 |
You should be fine as long as you don't drive it in the rain. I would also check with state laws and see if you are required to have them for state inspection (if that even applies to Hawaii)
__________________
#14 |
I have the driver side on because I got busted by the police for not having wipers.
__________________
1986 SVO: turbo'd fun! SOLD:'82 MUSTANG GT: 88' HO, 5-spd, 3.73s, & 17" Borbet Type-A wheels... and other goodies RIP: '82 Mecury Capri 5.0 : good times..... 1969 Chevrolet Chevelle: "the other four eye" |
#16 |
Parts Destroyer
Here in florida rain can come anytime, I have always kept wipers. However if it is going to interfere with you set-up then you won't have much choice.
#17 |
Except to put the above the windshield but then youd need to rid the sun visors
__________________
#18 |
I run rain-x on my car most all the time and i hardly ever have to use the wippers, i was contemplating deleting them as well. But like someone said up there, when your sitting still the rain-x doesn't do much, especially in that speed range where the wind is keeping it from falling but gravity is keeping it from sliding upwards. I would say you would be fine as long as you don't have to sit in traffic in a downpour.
ps i like how NO ONE on here told the guy to just go with a different setup. HA cosmetics and semi-functional things must always be done away with if they are hindering our performance. LOL
__________________
1985 Mustang GT: 347 stroker Holley 750 double pumper xe274hr comp cam Victor jr. intake RPM aluminum heads roller rockers equal length shorty headers electric fan afco aluminum radiator american thunder series flowmasters pace setter off road h-pipe chrome OEM cobra rims |
#19 |
Rain X and Fast = No Wipers
Rain X and Slow = Hang your Head out the window |
#20 |
I love rain-x. Even at slow speeds, the water may not run off, but it beads and if you look through it and not at it (the windshield) it still helps a lot instead of the layer/sheet of water without it. If you plan to run it on the street at all check local laws though. As mentioned a few times above they may be required. I think someone even mentioned our state-- No need for a windshield, but you must have functional wipers.
__________________
83 5.0 GT. Quicker than it looks! 10:1 (or just over) 306, Motorsport a332 cam, 140A alt, t5 conv, 8.8 w/ 3.27's, Edel rpm, alum rad, very worked e7's, Holley SA carb, etc... "Never underestimate the power of stupid people in large groups" |
#21 |
.. let me be the first then to suggest a different air filter system.
![]() The setup in that first pic is for a dedicated race car, and it is leading to a huge intercooler and icebox, probably sitting in the passenger seat. Is that what you're planning on doing? Otherwise I'm not sure I see the function. There isn't going to be any kind of ram air function, although I supposed it will be cold, maybe even a little colder than the fenderwell. Not trying to be a downer, but I know I've been caught in sudden downpours, stuck in traffic on the way home, with worn out wiper blades and it sucks. If you're really stuck on the idea, I would suggest finding a way to keep the drivers arm functional, even if it means cutting/fabricating the rods.
__________________
Marc aka tripice351. 84.5 GT-350 2.3T, 89 Vert 5.0, 54 F-250 390FE, and a few more.. Please click here to check out my parts for sale on eBay. |
#22 |
I've seen that thing running at 140 plus at Ford's utterly HUGE oval test track in Romeo MI. Impressive, to say the least. Both the car and the track. If I remember right the track is 7 miles around!
I had a 61 Starliner for a few years. Mine had "only" a 428 SCJ in it. With a top loader 4 speed. My brother has it now, minus the engine. If you gotta sell your Hot Rod, sell it to family, you still get to enjoy it, and maybe you can get it back someday. Sorry for the Hi-jack. Up here in MI, our hot rods may not have heat, but not having wipers is not an option. I wish I could be rid of 'em. The cowl area could be used for a lot of things other then windshield wipers. Last edited by Peganit2; 12-17-2007 at 10:04 PM. |
| Tags |
| no wipers, wiper delete, wipers |
| Thread Tools | |
| Display Modes | |
