#1 |
So I searched and searched but I'm just confused.
I have a 302 roller transplant in my 86. I pulled the starter and found the following numbers: A big 24, under that E7TE, and under that a small CA. I think its a 87 truck engine am I close? Thanks! Last edited by KAILUAZ; 11-16-2007 at 10:47 AM. Reason: Added all engine numbers |
#2 |
The Decoder Guy
It's an '87 and LATER truck block. To know the exact year you need the date casting, which is in the same area.
__________________
'83 GT, '84 LTD LX, '85 LTD LX (parts car), '96 B2300 SE, '99 CVPI |
#3 |
Ill have to look at the date casting once I pull it (thats the dial looking thing correct?).
There are people saying truck engines didnt come with a roller cam? Any truth to that? The head casting numbers are E6SE. No idea if the pistons are flat, the heads are still on. Last edited by KAILUAZ; 11-06-2007 at 05:01 PM. |
#4 |
The Decoder Guy
The dial looking thing is the shift and time.
The date casting will be a number, then a letter, then one or two more numbers. |
#5 | |
From another site:
Quote:
#6 |
The date casting looks like a metal tag attached with 2 screws .
It is not of course , but looks like it .
__________________
clowns to the left of me , Jokers to the right |
#7 |
Cool I was wondering what that was,, let me check it out,, its pretty dirty.
#9 |
The Decoder Guy
7A5 = January 5, 1987
#10 |
that ain't much sludge.
i still see rod cap bolt heads!!!!
__________________
'83 glx vert with '82 gt frontend if you aren't trying to blow the horn with the signal lever and reaching for the key release button on your other vehicles,you're not driving the fox enough ! |
#11 |
I just found the partial VIN, HX214448, so its a 87 out of the St Thomas plant, sequence number is between 100001 and 600000 which makes it a Crown Vic engine.
| Tags |
| block casting number, date code, numbers matching, partial vin, serial number |
| Thread Tools | |
| Display Modes | |
