#1 |
Like the title says, I can get this for cheap, looking for opinions.
If you do have one how are you mounting it?
#2 |
New User
I have one. It's installed using the ancient art of zip ties!!
__________________
85 GT T-Top, GT40P Explorer longblock, Holley 600cfm carb, Edelbrock Performer RPM Air Gap, TFS Stage 1 cam, JBA shorty headers. |
#3 |
Nice.
__________________
1988 lx vert Rebuilt enigne with gt 40 head's and intake's. ffrp aluminum radiator, mm subs, pro3i adj lower arm's, frrp 373, flowmaster catback, Magnaflow catd X,75 pro m menter. and more stuff. Soon to come new black top. (this summer) |
#4 |
Moderator
Oh, I too wish to learn this ancient art. Who was your master? Pu Ling Yu?
Dean T
__________________
Proud owner of the one and only Friggin' Futura |
#5 |
Many people run this fan. It pulls more air than any other fan that I have heard of. There is lots of information on this site and others for installing it if you do a little searching.
I'm personally running the same fan in two of my cars......but they're both Mark VIII's...lol.
__________________
My other Hobby: http://www.youtube.com/watch?v=yAbned6KxQw http://www.youtube.com/watch?v=-fXulOk14D4 |
#6 |
I trimmed the edge of mine (depth) and rivited mounting tabs like the stock schroud. A 3g alternator is a must as they draw many amps. I'm running a DCcontroller too.
__________________
79 Notch, 5.0 EFI, AOD, 3G, complete 90 GT running gear, Full length sub frames, Dynomax cat back, Mark VIII & DC controller. |
#7 |
FEP User
I have mine mounted with a cheap kit that goes thru the radiator. After I trimmed it down to depth to clear the waterpump pulley. I wrapped a piece of hatch seal around the edge, Looks great and it covers my butchery on the cut.
__________________
The only thing worse than a bunch of constuction workers who cant whistle is a bunch of consrtuction workers who cant whistle trying to whistle together. |
#8 |
Completely Nuts
I have one that I plan on tossing in the LTD LX. I have a 3.8L Ford Taurus fan in the Mustang with a DC control unit too.
__________________
1985 Mustang GT4bbl 5 spd, 1985 LTD LX AOD Cardomain: http://www.cardomain.com/ride/565542 Myspace: http://www.myspace.com/e4drht |
#10 |
New User
Same here. and have replaced the motor on one of them already. Make a note of the part number and rotation direction before you put it in. It'll make life easier when the time comes to replace that one.
#11 |
does any one have pics?
I have a lincoln mrk VIII fan as well. trimmed to fit but not in stalled yet. not sure how to make it permanent
__________________
mustang gt registry http://www.mustanggt.org/forums/inde...eferrerid=3400 F irst O n R ace D ay |
#12 |
funny enough, they pull so much air, all the hemi ram guys are installing them into their trucks too. I've got one that's gonna go into my hemi ram, or the mustang, lol I haven't decided yet. Guess I need to pick one up for both vehicles.
__________________
Jeremy -86 mustang SSP X CHP Unit # 3788-bone stock & staying that way -66 mustang, gt40y aluminum headed crate motor, t5, 8.8 rear -66 Mustang c code 65c bench seat car....roller, future project -72 Maverick 5.0 resto in process Entire 1986 electrical and vacuum troubleshooting manual download http://slantnosefox.com/picturehosti...g%20manual.zip |
#13 | |
Quote:
already done one....no problems :-) Do you post under the same name on the lincoln boards? Seems familiar.
__________________
#14 |
I used one from a 87 turbo coupethey have dual electric fans
#15 |
Completely Nuts
Those are known for having problems.
__________________
#16 |
Moderator
Right now it looks like only folks who belong to the corral, stangnet and one other forum can order the dc controllers. I get a web page that says that and that's as far as I can get.
No dc controller for me, I guess. Dean T
__________________
#17 |
I havent had any problems with mine it's been on my car for a little under two years. What happens to the turbo coupe fans? So I know what to look for.
#18 |
FEP User
Just be sure not to use a weak relay or cheap fuse holder with it. They wont last long. Great fan though.
Found this old pic of some 30 amp fuses/holders that came with a cheap controller from Jegs, cant remember the name off hand. The radiator probe worked ok I guess since it was adjustable, but the amp draw from that fan was way too much for the fuses and 30/40 relays over time. Ended up using a bosch 75 amp relay.
#19 |
Signup on either of the two forums that you mention is free and easy.....unless you have been banned? or just dislike them.
__________________
#20 |
Dean sign up on the corral and you'll be fine. I need to order two, one for the stang and one for my suburban. Now my question is which color line does which speed and which is ground? I guess i could research it out or just test it with a car battery or battery charger.
__________________
84 Mustang GT, 91 roller motor, SEFI conversion, MSD ignition, B cam, welded subs, aftermarket upper control arms, g-force t5z tranny, 3.73 gears in 8.8, rear disc conversion. |
#21 |
New User
Here are some pics of my installation, I did not have to trim it, only turn it upside down, attached it with zip ties, wired it using the stock Mark VIII power distribution box, running the 50 amp fuse and 30 amp relay, for the moment I turn it on and off manually, I'll replace that with a controller box as soon as I start working again, what do you guys thinks is better the SPAL or DC controller box?
__________________
85 GT T-Top, GT40P Explorer longblock, Holley 600cfm carb, Edelbrock Performer RPM Air Gap, TFS Stage 1 cam, JBA shorty headers. Last edited by 85tjstang; 10-31-2007 at 12:43 PM. |
#22 |
From what I read on the corral the DCC fan controller is behind on being produced and there is about a 60 day+ wait from the time it is ordered.
__________________
83 GT Turbo 84 GT Turbo (on it's way) 84 RS Turbo (Rotter) 86 Capri (Project Green Bean) |
#23 | |
New User
Quote:
You can confirm this by testing the fan with a car battery, just be aware that the newer fan will cause a big short if you connect the center spade to current, Just ask me how I know hope this helps you all out
__________________
#24 |
There's a good write up on the corral with installing a Taurus fan and using a Flex-a-lite fan controller from Summit. Better than waiting 60 days for a DC controller.
http://www.corral.net/forums/showthr...18#post7143518 |
| Tags |
| electric fan, lsc, lsc fan, mark viii |
| Thread Tools | |
| Display Modes | |
