Four Eyed Forums
Go Back   Four Eyed Forums > Tech > Race Tech and Dyno
Reply
Thread Tools Display Modes
Old 07-02-2007, 09:13 PM   #1
KAILUAZ
KAILUAZ's Avatar
KAILUAZ will become famous soon enoughKAILUAZ will become famous soon enough
Arrow Manual brakes, anyone running them?
Anyone switch to manual brakes? I'm looking at the Maximum kit for my 86 road racer.
__________________
911 NEVER FORGET!!
MILStang
KAILUAZ is offline   Reply With Quote
Old 07-02-2007, 09:55 PM   #2
4eye4valve
4eye4valve's Avatar
4eye4valve is on a distinguished road
May i ask why you want to switch? I have manual brakes on my car with four wheel discs from a 95 cobra. Doesnt stop very well. I have to stand on the brakes to slow it down.
4eye4valve is offline   Reply With Quote
Old 07-02-2007, 10:09 PM   #3
woody
New User
woody is on a distinguished road
Been running them for years, not a problem personally
__________________
FordStrokers
woody is offline   Reply With Quote
Old 07-02-2007, 10:51 PM   #4
KAILUAZ
KAILUAZ's Avatar
Looking to get better pedal feel. I know how to threshold brake so no need to stand on them. The MM kit gives you better leverage with their pedal design.
__________________
911 NEVER FORGET!!
MILStang
Old 08-01-2007, 10:06 AM   #5
KAILUAZ
KAILUAZ's Avatar
My plan is LSC rear end, SN95 front disks, 85 Town Car master cylinder, Summit proportioning valve, MM manual brake kit.
Anyone else have a similar setup?
__________________
911 NEVER FORGET!!
MILStang
Old 08-11-2007, 09:09 PM   #6
papis408
FEP User
papis408
I just ordered the MM kit. It should be here Wednesday. I have a Wilwood master cylinder w/ over a 1" bore(can't remember right now) that's what they recommend. They also state you should have upgraded brakes all around. I have Aerospace on all 4 corners.
papis408 is offline   Reply With Quote
Old 08-11-2007, 10:17 PM   #7
KAILUAZ
KAILUAZ's Avatar
Quote:
Cool, let me know how the kit works out.
__________________
911 NEVER FORGET!!
MILStang
Old 08-12-2007, 01:52 AM   #8
CP86SVO
New User
CP86SVO's Avatar
CP86SVO is on a distinguished road
I have the MM Manual brake pedal kit on my open track SVO, using 11.65" Cobra rear brakes, 13" Brembo front brakes and a 15/16" Cobra master cylinder...works great!
HTH WS
CP86SVO is offline   Reply With Quote
Old 08-12-2007, 08:20 PM   #9
papis408
FEP User
papis408
Quote:
HTH WS
How's the pedal feel vs power assisted?
Old 08-12-2007, 08:24 PM   #10
Mr Joshua
Mr Joshua's Avatar
Mr Joshua has much to be proud ofMr Joshua has much to be proud ofMr Joshua has much to be proud ofMr Joshua has much to be proud ofMr Joshua has much to be proud ofMr Joshua has much to be proud ofMr Joshua has much to be proud ofMr Joshua has much to be proud of
Send a message via AIM to Mr Joshua Send a message via Yahoo to Mr Joshua
I thought about buying one for my car, and after talking to the tech at MM, he convinced me it was in my best intrests to stick w/ the vaccum assisted brakes as i was going to do a fair amount of street driving..
IMO. i'm happy with my brake system (for now)
__________________
83 GT w/ T-Tops(JeffCleaned)
Mr Joshua is offline   Reply With Quote
Old 08-13-2007, 02:37 AM   #11
CP86SVO
New User
CP86SVO's Avatar
Very firm, but linear...the more you push, the more braking you get. You can still lock the wheels if you push hard enough...but I'm a cyclist and can leg press over 700 lbs several times easily.
It's a bit of a legful for street driving, but when open tracking, it can't be beat.
HTH WS
Old 08-13-2007, 08:09 AM   #12
Mike Croke
Lord Almighty Dukeship
Mike Croke has disabled reputation
I run manual brakes on my '79 Capri. I used the pedal and firewall plate from a junkyard car that originally came with manual brakes. It does take more effort but I don't think it's too bad.
Mike Croke is offline   Reply With Quote
Old 08-18-2007, 02:41 PM   #13
sleepercoupe
sleepercoupe
Send a message via AIM to sleepercoupe
just remember to change the pedal whatever you do!
__________________
1973 Mustang Sportroof 5.8C
1974 IH 1010 6.4L
1983 Crimson Cat 5.0L
1985 LTD LX 5.0L
1986 SVO 2.3T
1989 Mustang Coupe 5.0L
sleepercoupe is offline   Reply With Quote
Old 08-18-2007, 05:43 PM   #14
KAILUAZ
KAILUAZ's Avatar
Quote:
Nice that its adjustable also.
__________________
911 NEVER FORGET!!
MILStang
Old 08-19-2007, 03:06 AM   #15
Dean_T
Moderator
Dean_T's Avatar
Dean_T is a jewel in the roughDean_T is a jewel in the roughDean_T is a jewel in the roughDean_T is a jewel in the rough
Now, I seem to recall the auto trans cars have a different manual pedal than the manual trans cars in terms of non-power brake pedals. Is this really true and could a person mix 'em? I have two of them floating around somewhere (I think I even grabbed the push rods along with the adapter plate) but unfortunately, I do not remember the transmission type I grabbed them from.
If '65 Mustangs are any relevance, my previous V8 '65 Mustang with factory front disc brakes was manual (of course, power was not an option for front discs in '65) and it felt fine to me.
I have a hunkering to convert my '83 Fairmont to manual to see how much I can push the weight issue with it.
Dean T
__________________
Dean_T is offline   Reply With Quote
Old 08-25-2007, 04:06 PM   #16
Satanpez
Satanpez
Send a message via AIM to Satanpez
Quote:
Dean T
You can mix a manual break pedal between all boxes. There are (at least) two types of manual pedals, automatic & manual shift. Either will fit into any pedal box, however the pivot moves to a different spot. The hole should be there for that separate spot.
My '82 came with an automatic & manual brakes. I converted to stick shift by putting in my pedal box from my '90 but put the manual brake pedal into that new box. The only problem I have is the pedal is a little large but I can shape it to fit.
I'm using the 1" Lincoln M/C w/ '96 disk brakes all the way around. I like the feel. I've also had a '65 Mustang and '65 Falcon with manual brakes so I'm quite used to it.
-Steve in NJ
Satanpez is offline   Reply With Quote
Reply
Tags
brakes, lsc, manual, manual brakes, master cylinder
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
