Four Eyed Forums
Go Back   Four Eyed Forums > Tech > Mods, Maintenance and Mechanicals
Notices
Reply
Thread Tools Display Modes
Old 09-13-2004, 10:08 PM   #1
mfpmax
mfpmax's Avatar
mfpmax is a glorious beacon of lightmfpmax is a glorious beacon of lightmfpmax is a glorious beacon of lightmfpmax is a glorious beacon of lightmfpmax is a glorious beacon of lightmfpmax is a glorious beacon of light
Default Headlight Relay modification (PICS)
First, this thread
http://www.foureyedpride.com/phpBB2/...ghlight=relays
As it contains much of the information needed.
Went to the parts store and purchased 2 40 amp relays(I recommend ordering them from http://www.partsexpress.com as they are much cheaper). Also picked up a 30 amp breaker as well, along with overpriced connectors(all higher amperage connectors were soldered).
The first picture is the voltage while running at idle on the low beam side, the second picture below it is the high beam side. I didn't take readings before I installed the relays unfortunately.
The next two pictures are the low beams.
The next two pictures are the high beams.
And there you have it. If you can solder decently and can read simple schematics, I recommend you do this. If you can't really solder too well, Painless Wiring sells a relay kit that is identical to most of the parts I used except I believe it is ready to wire in...which is REALLY simple. You can either splice into the orignal wiring, or purchase new connectors to go onto the headlights.
__________________
Turbo POS - 1986 Mustang Coupe
The internet is a series of tubes...seriously
http://www.kevinrant.com/ Woooo Ha!
mfpmax is offline   Reply With Quote
Old 09-14-2004, 04:40 AM   #2
Anonymous
New User
Anonymous
'bout how long did that take ya?
--Dave.
Anonymous is offline   Reply With Quote
Old 09-14-2004, 11:33 AM   #3
mfpmax
mfpmax's Avatar
Quote:
--Dave.
Shouldn't take long, maybe an hour at most, or two if you're being real picky. Took me longer cause i'm anal, and then it rained a few times.
__________________
Old 09-14-2004, 04:21 PM   #4
joelliott
joelliott's Avatar
joelliott is a glorious beacon of lightjoelliott is a glorious beacon of lightjoelliott is a glorious beacon of lightjoelliott is a glorious beacon of lightjoelliott is a glorious beacon of light
Send a message via MSN to joelliott
nice work there man. Thanks for the picts too, it really helps us understand whats goin on. About the voltages? I have a stock alt and elect system. I have been concerned about it being weak and draining the battery. Althought it hasnt. yet. My sysem runs anywhere from 12.5 V to 14.5 V on normal driving. ei lights, radio, radar detector, etc. If I attempted this mod, would I have to worry about more battery drain? Or is hte voltage difference not that much? Plus, Im a handy guy, but not a mechanic or electrician. Can it be done by a good direction follower? Thanks
Joe E.
__________________
Joe E.
1985 GT 5.0L HO
http://www.sounddomain.com/ride/2128421
joelliott is offline   Reply With Quote
Old 09-14-2004, 06:06 PM   #5
mfpmax
mfpmax's Avatar
I personally haven't a clue about the drain as of yet, but I have the same concerns as you. I would assume with a stock system, and the normal drain(IE no fancy high power aftermarket stereo), it should be okay, but I'd recommend a alternator upgrade anyway, i've been looking at doing one forever myself.
As for doing it, I would think so, following the diagrahm that Mike Choke has in the the link at the top of the thread, it should be simple, only need to find the correct wiring and splice into it correctly.
__________________
Old 09-14-2004, 06:16 PM   #6
BetterDays
BetterDays is an unknown quantity at this point
Quote:
Originally Posted by mfpmax
... but I'd recommend a alternator upgrade anyway, i've been looking at doing one forever myself.
Summit - Powermaster 140AMP one wire.... Yea!
BetterDays is offline   Reply With Quote
Old 09-15-2004, 12:17 PM   #7
Matt82GT
Matt82GT
Send a message via AIM to Matt82GT Send a message via Yahoo to Matt82GT
__________________
87 TC
Matt82GT is offline   Reply With Quote
Old 09-15-2004, 12:20 PM   #8
mfpmax
mfpmax's Avatar
What huh...nothing...
__________________
Old 09-15-2004, 12:41 PM   #9
Matt82GT
Matt82GT
in english please.
__________________
87 TC
Old 07-12-2007, 11:23 AM   #10
mcb82gt
mcb82gt's Avatar
mcb82gt has a spectacular aura aboutmcb82gt has a spectacular aura aboutmcb82gt has a spectacular aura about
I have to bring this old thread up, the link with the info is a dead horse.
__________________
Now stang-less.
88 Cougar 5.0
mcb82gt is offline   Reply With Quote
Old 07-12-2007, 11:50 AM   #11
Mike Croke
Lord Almighty Dukeship
Mike Croke has disabled reputation
Here is how I did mine:
This guy did a more thorough job of documenting:
http://vb.foureyedpride.com/showthre...ghlight=relays
Mike Croke is offline   Reply With Quote
Old 07-12-2007, 04:26 PM   #12
mfpmax
mfpmax's Avatar
He also has a fancy smancy box
__________________
Old 07-13-2007, 08:57 AM   #13
mcb82gt
mcb82gt's Avatar
Are relays all different? On the relay wiring, Daniel Stern's lighting site has
http://www.danielsternlighting.com/t...ys/relays.html
85 ground
86 multi switch input
30 starter solenoid
87 headlights
It said you can get a relay with two 87 terminals, run one to left and one to right side.
__________________
Now stang-less.
88 Cougar 5.0
Old 07-13-2007, 10:21 AM   #14
FoxChassis
The Decoder Guy
FoxChassis's Avatar
FoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant futureFoxChassis has a brilliant future
Yeah, not sure what's going on with Croke's diagram but the terminal configuration at Stern's 'site is correct.
If you want a mini 40A SPST relay w/ dual "87" outputs, here are the Hella part numbers:
87453 - w/ bracket, w/ diode
87452 - w/o bracket, w/ diode
87118 - w/ bracket, w/o diode or resistor
87483 - w/o bracket, w/o diode or resistor
"87a" is NOT a second "87" terminal.
__________________
'83 GT, '84 LTD LX, '85 LTD LX (parts car), '96 B2300 SE, '99 CVPI
FoxChassis is offline   Reply With Quote
Old 07-13-2007, 12:10 PM   #15
mfpmax
mfpmax's Avatar
I had no problems with Croke's diagram.
__________________
Old 07-13-2007, 01:33 PM   #16
mcb82gt
mcb82gt's Avatar
Do I need the relay with or without diode/resistor? What is the function of it in this application? Sorry for my electrical ignorance.
__________________
Now stang-less.
88 Cougar 5.0
Old 07-13-2007, 01:34 PM   #17
93-331-29PSI
93-331-29PSI's Avatar
93-331-29PSI is a splendid one to behold93-331-29PSI is a splendid one to behold93-331-29PSI is a splendid one to behold93-331-29PSI is a splendid one to behold93-331-29PSI is a splendid one to behold93-331-29PSI is a splendid one to behold93-331-29PSI is a splendid one to behold
My wiring was done exactly like the one on Daniel Stern's site and I had no problems.
__________________
83 GT Turbo
84 GT Turbo (on it's way)
84 RS Turbo (Rotter)
86 Capri (Project Green Bean)
93-331-29PSI is offline   Reply With Quote
Old 07-13-2007, 01:44 PM   #18
FoxChassis
The Decoder Guy
FoxChassis's Avatar
Quote:
http://www.rallylights.com/hella/Relays.asp
Eliminating voltage spikes:
Voltage spikes from 300V to 500V can occur momentarily when a relay is switched off. Sensitive electronic equipment can be damaged or malfunctions can occur if these spikes reach the vehicle electrical network without suppression. A relay with a resistor reduces these voltage spikes to less than 100 Volts. A relay with a diode eliminates them completely. The correct polarity of the connections is marked on the diode protected relay.
Old 07-13-2007, 10:28 PM   #19
ujslost
ujslost's Avatar
ujslost is on a distinguished road
Ok since I am new to the 4 eyes. Please explain this to me like Im a 2 year old. Why are you guys doing this mod?
__________________
79 Coupe
5.0 swap complete, T5 swap complete, 8.8 swap complete. 13.9s @98
ujslost is offline   Reply With Quote
Old 07-13-2007, 10:35 PM   #20
FoxChassis
The Decoder Guy
FoxChassis's Avatar
mcb82gt posted this link:
You should read that page.
Old 07-13-2007, 10:44 PM   #21
ujslost
ujslost's Avatar
Ok I read some of that just now and skimmed over some of it just to get an idea of whats going on.
Could this fix the problem i recently encountered? I was doing some work on my car. I had left the headlights on without the engine runnin. Next i smell a burning wire smell. i pull the headlight switch connector off the switch and find this.
__________________
79 Coupe
Old 07-13-2007, 10:54 PM   #22
FoxChassis
The Decoder Guy
FoxChassis's Avatar
That probably happened because the terminals were old, corrorded, dirty, or all three. Any or all will increase resistance. Then the wires and connectors heat up, creating more resistance. Add to all of that the draw of the headlamps and it heats everything up even more. Eventually you get what you got....burnt connectors, wires, terminals, or worse yet, an electrical fire that could cause some real damage (to the vehicle and or you).
Replace the headlamp switch, that connector, and any of the damaged wiring and terminals, then set up a relay circuit for the headlamps. You shouldn't have any more problems with that headlamp circuit, AND the headlamps will be brighter than if they were just running through the factory circuits.
If you eventually want to replace the sealed-beam headlamps with an H4/H1 conversion 'kit', the wiring will already be done and the conversion will just be plug-n-play.
Old 07-13-2007, 10:57 PM   #23
ujslost
ujslost's Avatar
ok so just replace that connector, then do this mod? Thanks.
anyone got one of these headlight switch connectors they want to donate to the hope my car dont catch a fire charity? (especially while i got my beautiful daughter in ther with me)
__________________
79 Coupe
Old 07-13-2007, 11:06 PM   #24
FoxChassis
The Decoder Guy
FoxChassis's Avatar
You should be able to get that connector, with about a six inches of new wiring, at any auto parts store.
Old 07-13-2007, 11:09 PM   #25
ujslost
ujslost's Avatar
oh, well ok.
ford headlight harnesses were notorious for burning up , i had a 94 ranger that did I had to replace the harness connector at the bulbs
__________________
79 Coupe
Reply
Tags
archive, headlight, headlight upgrade
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
