So today we received our shipment of interior paint from NPD. Here is a guide to dyeing your interior panels and what you'll need to do. oh boy, this is gonna be interesting.
Prep:
This is VERY important. just like exterior paint on a car, prepping the interior panels is the key to getting a good finish on your panels.
Step 1:
The first step is to sand any areas with scratches or gouges. This is in order to eliminate any loose plastic that can become more apparent after you have painted the plastic. The recommended sandpaper is 400 grit.
We also used a foam sanding block to wrap the sandpaper around, this keeps your sanding nice and flat.
Step 2:
The second step is to clean the plastic. I recommend using dawn dish soap with a scotch brite pad to really clean the plastic well. Another Cleaner that works well is citrus cleaner.
Step 3:
The next step is to use SEM Plastic and Leather Prep. With this you simply spray it all over the plastic, and then wipe it off immediately.
Step 4:
The other can pictured is SEM Plastic Adhesion Promoter. THIS IS ONLY FOR PLASTIC PREP. With this stuff you have to apply a light coat on the panel, and then let it dry for 5 minutes, and then apply a second, slightly thicker coat, and let that dry for 15 minutes.
Painting
FINALLY! Its quite the long process, painting these pieces.
Ok, this is the simplest part of the process, simply apply the dye in the number of coats needed. Trust me on this: this dye is AMAZING. If you complete the process right, it turns out incredible. MAKE SURE TO USE NATIONAL PARTS DEPOT LOW-LUSTER FOR BASECOAT, SEMI-GLOSS FOR FINISH COAT
