#1 |
Where would one look to find the build sheet in an 85 GT convertible?
Thanks, Rob
__________________
1985 Mustang GT Vert Factory Medium Canyon Red, original top, gray leather, 5-speed, stock premium sound, Flowmaster 40's, BBK x-pipe, MM SFCs, polished 10 holes, Enkei black mesh, 3:73's Past Rides '82 GT '84 GT '89 GT '90 GT '96 GT '00 GT vert |
#2 |
many people find the build sheet under the carpet, sometimes under the rear portion where a rear passengers feet would be.
#3 |
The Decoder Guy
Most common location is where eeprete said.
Also can be... under bottom portion of rear seat under hatchback carpet under spare tire behind interior quarter panels
__________________
Looking for: 1986 5.0L coupe or 1986 "blue" Saleen Wanted (Dead or Alive): VINs, door tags, buck tags, build sheets, window stickers, owner cards, transmission tags, axle tags |
#4 |
Why do they seem to hide it? Why would it be placed in different locations? Just seems random that they would be placed in different locations in the same year/model.
Thanks, Rob
__________________
#5 |
The Decoder Guy
Not even supposed to be in the car. But it was easier to keep or throw them in the car that throw them in the trash.
#6 |
good luck!! I've been trying to find the one in my 85 GT Convertible for sometime now!!! its was a piece of cake on my 85 GT hatchback...it was right under the carpet behind the front passenger's seat. I can't find it anywhere on the ragtop. maybe this had something to do with the convertible conversion when they took things apart to cut the tops?? don't know just guessing....let me know if you find yours, I've run out of places to look short of removing the entire interior...
__________________
89 LX NOTCH (1C) 5.0L 5SPD 86 GT VERT (2R) Tu-Tone 5.0L 5 SPD Last Built 86 GT Convertible |
#7 | |
Quote:
#8 |
YUUUP!
Most likely the build sheets are in different locations because Dearborn ran a two shift operation... the person doing the job on day shift would put it in one spot that was different than the person doing the job on afternoon shift... believe it or not, disposing of the build sheet is a element on a person's job... like eeprete and FoxChassis said the build sheets are not to be there.
__________________
Past Mustangs: 1965 "K" Code Coupe... 289/271HP 4 speed Poppy Red 1986 GT... Canyon Red 5 speed 2002 GT... Silver Automatic 2003 Mach 1... Azure Blue 5 speed Current Cars: 1986 Mustang LX 5.0L Coupe 1996 Escort LX 2 Door 2011 Ford Fusion SEL |
#9 |
I understand guys...that they were not supposed to be there..I'm just in denial that maybe my car was one of the ones that they actually followed the correct protocol. I have to believe its in here somewhere, I just have to probably take everything out, just not willing at this point. My odds are good that atleast one of the many build sheets for my car is insome crazy little corner all smooshed up.
Rob...post some more pictures of your car...ours looks pretty similar in condition and mileage.
__________________
#10 |
Moderator
Yes, you need to completely remove your interior to be sure.
-Mike
__________________
CLICK HERE FOR A TROVE OF FACTORY CAPRI LITERATURE! |
#11 |
I found one in a 82 last summer stuffed into the seat springs and foam under the front seat.
#12 | |
Quote:
Unless anything needed to be removed I would not bother Tony. If you have to do quarter window motors at some point you'll know for sure. Perhaps you have a Tuesday or Wed car and they were doing Job 1 that day. |
#13 |
I will be doing my rear triangle windows in the next couple weeks, so I will let you guys know if I can locate the build sheet in my 85 convert.
Rob
__________________
#14 |
thanks Ed, I'll try not to get carried away....but sometimes I can get crazy looking for something...
__________________
#15 |
I had my 85 GT taken completely apart. It was a shell on jackstands. The build sheet was not in it anywhere. OR Someone else found it before I bought the car. My 84 didn't have one either. Hopefully I can find one in my Fairmont Wagon and Zephyr Z7 When I tear into them. Good luck.
__________________
79 Mustang COBRA 302/C4 (sold) 82 Zephyr Z7 200 I6/C5 (daily driver work car) 78 Fairmont Wagon 5.0/5spd (possibly selling it) 80 Mustang coupe (sold) 84 Mustang coupe 5.0/5spd (gave to my son) 85 Mustang GT 5.0/auto "Wifes" 87 Mustang Coupe 5.0/C4 (sold) 88 Mustang Coupe 5.0/5spd (sold) 90 Mustang Hatch 2.3/5spd (traded) Load it like a boxcar........drive it like a dragcar!!!!!!!!! |
#16 | |
Quote:
__________________
#17 |
New User
found mine behind the driver side rear passenger panel by the window
#18 |
The Decoder Guy
Do you still have it? Can you take a pic of it or scan it, and post it?
| Thread Tools | |
| Display Modes | |
