Results 1 to 11 of 11
    Default Budget engine swap/regasket
    Figured I go ahead and ask this here to cover my bases.
    I’m currently collecting the parts and gaskets to drop my 96 exploder 5.0 into my LTD and just curious if there is a good list of things to replace while the motor is out of the car.
    Car will be a fair weather cruiser/(future) bruiser.
    Buying all the good Fel-Pro gaskets.
    So far I have:
    Intake manifold set (96 explorer)
    Oil pan gasket (1 piece steel/rubber)
    Thermostat
    Timing cover/Water pump (86 Mustang)
    Items I know I still need:
    Oil pan
    Oil pump/pick up
    Oil pump shaft
    Head gaskets (9333-pt1)
    Sensors (TPS/IAC/ACT/ECT/EGR)
    Head bolts (ARP)
    Valvesprings (Alex’s Parts)
    Timing chain (Cloyes)
    Throttle body gaskets
    Throttle body bolts
    Timing cover/Water pump bolts
    That’s what I can think of as a first timer reading what others have done. Definitely on a budget, but if any of you experienced guys can chime in with some things you’ve learned it would be much appreciated.
    96 being a gt40 3 bar head. I would recommend decking the heads for more compression. Oh and a well matched camshaft
    Apr 2008
    Waikoloa , Hawaii
    Sounds solid. Of course you'll have new fluids to factor in as well. I'd put new plugs in it while easily accessible.
    1986 CHP SSP Coupe
    Quote Originally Posted by Lowetlx View Post
    Really just trying to regasket and avoid the machine shop for now, and I’ll be running a stock 86 ho cam
    New fluids, plugs, wires, and cap and rotor will be added too
    Jul 2009
    Chicago, south subs
    Do you have a distributor/ignition?
    Yes I do
    Might as well do the rear main and front main seal too.
    '79 Indy pace car T-top
    '81 Cobra
    '81 Cobra T-top
    '82 Mustang GT T-top
    '87 Corvette
    '10 Mustang GT Convertible
    '17 F250
    '17 Landrover Discovery Sport
    Quote Originally Posted by gregpro50 View Post
    Already got the rear main when I ordered the parts for the t5 swap, and got the good felpro timing cover set with all the seals and stuff
    Jan 2003
    lansing, mi
    Take off the oil pan and remove the rear main cap when you do the rear main seal, otherwise don't bother.
    Cale
    One piece rear mains come right out with a small straight blade and hammer. Once they start turning they come out. The other thing I've used is sheetrock screws and makeshift slide hammer.
    reinstallation is easy. Buy two seals. Stack them. Use one to pound the other one in.....
    It has worked for me every time.
