Page 40 of 61 FirstFirst ... 30383940414250 ... LastLast
Results 976 to 1,000 of 1501
  1. #976
    Jul 2016
    Duncannon PA
    How far can you tub it before you run into the framerail?
  2. #977
    Almost any tubbing if I want 315's. The main contact area of the vehicle and tire will be the frame rail area immediately behind the mount area for the IRS. Just about exactly where quad shocks are mounted on the newer foxes. Though I will probably just bring the tubs in about 1.5", That rub area shouldn't be an issue in the end though. That's just the narrowest point on our tubs for inner tire scrub.
    I would need to notch the frame rail slightly for the needed coilovers since I'll loose the upper spring perch in the tubbing. Also I will need to make an upper mount for the coilovers to provide the needed support since all of the vehicle weight will be in that one area.
    I also will have to modify the IRS. The rear mounts will have to be narrowed. I will mount them 'hardtail' directly under the frame rails.
  3. #978
    Mar 2014
    Omaha, NE
    Crazy green and IRS? This car just keeps getting better and unique!
    I think the new color choice is cool! I loved the blue, but the green just stands out better to me. Maybe I just like different.
    Brock
  4. #979
    Mar 2014
    Omaha, NE
    Here’s something for anyone that’s got a good analytical brain.
    Think of anything that might cause issues for me trying to do both of the following things. I believe I can do it, I need to start measuring now though before I start cutting.
    i want to mini-tub and have an IRS. Biggest problems I see are the need for a custom swaybar and custom wheels. Backspacing numbers ought to be pretty incredible.
    Later this week I should be ordering the new floorpan, crossbrace, right front subframe and a couple other things finally.
    i hope to have the wife buttered up enough for me to pull the car into to the garage for about a three month stay as I redo practically everything on level or below the floorpan.
    Anyone have experience with HF plasma cutters? I want to use one for all the stuff that needs swapping, I just can’t imagine spending a lot for the cutter itself since I really won’t use it much after this part of the project.
    The HF plasma cutter will work fine up to about 1/8” metal. We have one at work and while it can get sketchy in the upper range, it works perfect for sheet metal up to about 3/16” with butter smooth perfect cuts.
    Brock
  5. #980
    IMHO the custom swaybar and wheels are the easy part. To minitub it, you are going to have to modify the cradle for the IRS or at least the mounting points for it. The front mounts to the stock front lower control arm and the back mounts where the quad shock would go. So if you move the frame rails inward at all you will have to modify both of the mounts on each side to compensate the same amount you move the frame rails inward.
    After that you will have to modify your lower shock mount most likely due to the frame rail change and/or your custom wheels. I assume you are planning on running a coil over setup at this point as I don't see how you can run a standard coil spring without modifying the cast aluminum lower control arm.
    The other issue I see that may be more personal taste than anything is the backspacing/offset on any wide wheels in a Fox with the Cobra IRS is going to be insane, but unfortunately still look pretty much like a FWD wheel. The Cobra IRS is the widest SN95 axle at @ 60.3" track width which is 1.5" wider per side than your current setup.
    I can tell you from my experience with my 79 PC and the 03/04 IRS that a 17X9 (9" wheel has a 36mm offset (@6.4" BS)) with a 255/40/17 just barely clears the rolled outer lips and has less than 0.5" of clearance between the wheel/tire and the rear cradle mount. Most likely you will be running a Corvette C6/7 offset/backspacing to make it all work.
    In regards to the Plasma cutter, I can't say anything about the HF unit as I have never used one. I did recently purchase the Eastwood Versa Cut 40 to do some work at the shop here in TX since my big Hypertherm is back in CO. So far I have been impressed with it. Very light and works on both 120/240. If you don't need the larger size, then consider the Versa Cut 20 that will do sheetmetal up to 1/8". I have seen the Eastwood on sale for I believe $299 Might be able to sell it after you are done and recoup most of your $$. Good Luck!
  6. #981
    I’m thinking the front mounts won’t need modifying. The rear cradle mounts without a doubt will need modification.
    i want to bring them in enough to hardtail mount them below the frame. I’ve got an idea on that one.
    I would have to get coilovers since the area where the springs mount on the frame rail will have to go.
    The reason for the custom sway sway bar is the coilover clearance when I move the upper shock mount inboard. This will be the area I need to modify the frame rail a little. A little slicing and dicing for an area for the coilover to be leaned in. The lower mount won’t be affected.
    i believe I will need a set of Kenny Brown lower control arms too. Maybe not need, more of a want. I’ve read about their problems but I believe i could rectify those issues. Do you know anyone else making an aftermarket lower?
  7. #982
    Sep 2010
    Lexington, MA
    This build just keeps getting better-and-better! 408 is an interesting choice, and I'm sure your late brother would approve. You might think about wheelie bars and a blower too, as the icing on the cake
  8. #983
    I missed your post clarifying a few things before I made my post so I apologize for repeating things you had already stated or answered.
    I don't disagree that the front mounts are probably fine, especially if you are only looking to fit a 315 rear tire.
    We concur on the coil over option, although I still have concerns as to what this will do to the actual dampening quality and wheel rates depending on where you end up placing the rear shock/coil spring upper mount. I can't go out and look at my set up right now to verify, so I will have to take your word that you feel the lower mount will be able to remain in it's current location. I too have looked at the KB lower and upper arms, but just haven't decided they were worth the $$ at this point. Nothing against them, just not sure they gain me enough to justify the $$ is all. I am not aware of any other options at this time myself.
    In regards to the upper mount for the rear shock/coil over setup I would highly recommend the MM Racing Rear upper shock mount http://www.maximummotorsports.com/Ra...IRS-P1089.aspx I think you may want that additional support and secure mounting depending on how you decide to make it work. You will definitely want a significant structure for the mount that can handle the loads that are required.
    I will admit that I too have considered an IRS with tubs, but I was considering narrowing the whole IRS setup to gain some additional room and improve the rear wheel visuals from my perspective. I have another Cobra IRS (non Terminator) that I just might do that with for one of the projects, then again I might just stuff it under the SVO and call it good! For all the custom work and expenses there are Ford 9" based aftermarket IRS that would probably save me a ton of time and money in the long run. Good Luck!
  9. #984
    Thanks Trey. I’ve allowed my brain to wonder a bit today. As you know the KB control arms cost $1400 for lowers and uppers. Yikes!
    How hard do you think it would be to make my own set of control arms? Get some chrome moly tubing, make some detailed measurements, create and jig and do some cutting and welding.
    I’ve given some thought of either making a set of arms that are shortened or possibly relocating their mounts a little more inboard and finding a half shaft that’s a couple inches shorter and move everything in. Hummmmm.....Sexier wheels that way.
  10. #985
    That color is
  11. #986
    Sep 2010
    Lexington, MA
    Quote Originally Posted by badnightrain View Post
    that is the one that got away from me
    I'll keep you posted.
  12. #987
    Anything is possible! The question is if it is worth all the time and expense? Only you can answer that. I would likely recommend using a program such as Suspension Analyzer to make sure anything you build will ride and handle as well as OEM, otherwise what is the point. Unfortunately a good IRS is just as complicated as a good IFS in design and fabrication, so not something you want to take lightly. Nothing that a good DIY'er can't tackle, but I feel you want to make sure you are making the car as good if not better, rather than just able to run wider wheels.
  13. #988
    Yeah, the whole tubbing thing is just speculation to see if it is possible or not.
    It helps me to talk through the varying thoughts.
    Like the halfshafts, couldn't i just disassemble them and send the shaft to Strange or Moser and have them shorten and respline them? They do that for sra axles.
  14. #989
    Quote Originally Posted by T-O-N-Y View Post
    That color is
    Thanks Tony, i'm calling the car Booger now based on the color.
  15. #990
    Quote Originally Posted by Bryan Knebworth View Post
    Wheelie bars? Not so much. Forced induction someday? i won't say it won't happen.
  16. #991
    I think that's the route i'll go. Someone else mentioned to me that Eastwood has a nice cheap one as well. Though I could go pick up one up from harbor freight before the weekend
  17. #992
    Thanks Brock.
  18. #993
    Mar 2014
    Omaha, NE
    Perfect!
    Brock
  19. #994
    Mar 2014
    Omaha, NE
    If you get the HF one, just get the replacement warranty that way it gets replaced free. Can’t be too careful with their “power” tools.
    Brock
  20. #995
    Honestly Brock, I can’t wait to get it. I’ll be cutting up anything I find probably! Then I can work
    on my welding skills putting it back together. Win-win, no?
  21. #996
    With your body work skills wouldn't it be easier to add a subtle 1 1/2" flare to the car? Wheel choice would be easier. IRS would be a bolt in deal, wouldn't have to re-engineer what Ford made. Car would look meaner being a little wider. Many wouldn't pick up on it at a glance.
    Jess
    Previously owned;
  22. #997
    FEP Super Member
    May 2003
    Roseburg Oregon
    Jess
    This is where i am at also.
    I installed an IRS from an 03 , into a 91notch .
    Only room you really need , is at the quarter side of the wheel house .
  23. #998
    I read this article this morning....it has me rethinking the IRS. This and the costs of upgrading the IRS.
    http://www.griggsracing.com/pdfFiles...e%20Debate.pdf
    One thing I hadn't considered in actually narrowing the IRS would be the angle of the CV joints, would that be beyond their capabilities?
  24. #999
    Griggs makes several good points. The caveat being that he is really addressing most of this from a competition angle and not a street car angle. This is especially true in regards to a Fox with the IRS since the IRS was an add on by Ford to a chassis that was originally designed in the late 70's and was never intended to have an IRS much less be a real road course handling car by any means. What Griggs, Maximum Motorsports, Agent 47, Kenny Brown, and others have been able to do with the Fox chassis over the years is really pretty amazing when consider the humble beginnings of the design.
    With all that said, I think the big question for you is what do you plan to do with the Mustang. Is this a street car or a track car or a hybrid of both? If this is a street car, then full on race tuning is neither needed or desirable in most cases. If this is a hybrid, then you will want to consider many upgrades to the IRS, if this is a full on race car, then you might want to reconsider the "Perfect Paint" if going Wheel to Wheel.
    Maximum Motorsports and Full Tilt Boogie Racing both offer several upgrades to the IRS that will improve the whole rear suspension even for the street car. Not necessarily cheap options, but definitely make improvements over the compromised OEM design. Everyone here knows I am a big proponent of Maximum Motorsports and their products, but I do have to admit that FTBR has done a ton of hands on work with the IRS and makes some very nice products. I have a few of them on my 79 PC and as the budget allows there will be more.
    I do have to agree with the statements above that doing a 1.5" flare kit to your Mustang may be the better option for what you want to accomplish with this Mustang. I would recommend the Maier Racing flares as IMHO the 1.5" kit is subtle but does give that added width that allows much wider wheels and tires at all four corners. YES, the kit will require some extensive body work to be perfect, but you have shown that is an area you are highly skilled in and shouldn't be an issue. I currently have their 1.5" fenders on my 85 Road Racer GT and I love the look, most people don't realize their are wider than stock and they look great. I still need to do the rear quarters, but not being home in CO and budget have not allowed that to happen just yet. I will say that with my experience with my PC and the IRS, adding the rear quarter flares should allow you to easily run a 10-10.5" rear wheel and possibly even an 11-11.5" if you go to the hard mount on the rear cradle with no clearance issues. That will be plenty of wheel for 315 tires and give you a subtle wide body that just looks killer.
    That would allow you to install the IRS as is without any need to modify the control arms, shock mounts or even Mini Tub the Mustang unless you just want the additional work. The flares will work with your stock front and rear bumper covers and all the stock side moldings, etc can still be attached to look like an original Mustang if you choose. I highly recommend checking into a Maier Racing's Website. https://www.maierracing.com/product-...79-93-mustang/
    Here is a picture of the Maier Racing 1.5 fenders I have.
    Name:  2018-01-12 12.22.34.jpg
    Here they are on the car with stock rear quarters at this time.
    Name:  2018-01-20 12.09.51.jpg
  25. #1000
    Haha personalized vanity plates??
