I attempted to replace my MAP sensor vacuum line today. Although it did not have a leak, it looks old and weathered, so I thought I would replace it.
I tried to locate where it connects under the top maniford (I think that is what you call it) with my Ogre hands but could not find it.
I then attempted to remove the top manifold. I had all the bolts out except for what appeared to be a bent arm bracket near the firewall. That bent arm bracket is connected with a double nut at the top and bottom of the arm. When I tried to remove the lower nut it stripped out. At this point I gave up and put everything back together.
Three Questions:
1) Where does the vacuum line connect to under the manifold? Any Pic's?
2) Can you hook up this vacuum line without removing the top manifold?
3) Is there any kind of write up or walk through for DIY beginners on how to remove the top manifold. Pictures really help.
Again, any information or help on this is much appreciated.
