I have a small leak on my "hard" line which is called the "RH and LH turn lines" respectively. These are the lines on the rack and pinion that are connected on both ends to the rack and pinion.
Under normal circumstances these two lines are NEVER to be removed from the R&P
These lines have a special Teflon seal that goes on the end of the line where the flare is. These are DIFFERENT than the R&P lines that goes to the PS pump and cooler respectively.
I am reaching out if anyone knows where to get these seals and/or have ever done this.
I am attaching a few pics and in the one pic I am referring to the red and blue hoses...
