I am installing the dead pedal that came on svo and later 5.0 cars. The only problem is that it is hard to tell how high it is supposed to be. Is it supposed to Beņat the same level as the clutch pedal or maybe lower?
Tony
This might be of some help. The instructions have a template you can use to locate the holes.
http://vb.foureyedpride.com/showthre...ght=dead+pedal
'97 Thunderbird
There are dimples in the floor sheet metal. The vert may have overlapping metal layer covering it, IIRC.
the Ford template and instructions for pedal help a lot.
Like they say can adjust mounting location to suit driver.
Adds comfort while cruising down the highway or bracing for a turn.
Thanks a lot, that’s perfect!
Tony
