The other day I couldn't get my Mustang to start after just moving it to edge of the driveway. I saw that the fuel gauge read 1/2 full. I assumed it was correct as I replaced the sending unit a few years back and I didn't think it would fail so quick.
After verifying spark at the coil and distributor, and fuel pump relay is energizing, it must bad the fuel pump, which is a Walbro I put in about the same time as the fuel tank sending float. Then I noticed my low fuel warning light was on. I had seen that a few days ago and tried swapping the sending switch behind the glow box but the light stayed on. Like a stunod I assumed the fuel gauge was correct and the dummy light was not. I was wrong.
Just to see, I added one gallon from a gas can and the car started. Now I'm curious how much gas is actually in the tank so I go to the gas station and fill it up. it took 14 gallons. That means it was bone dry. So after my fill-up I see the gas gauge goes far right and after a few minutes driving it the needle hides so far off the scale I had to hold my camera sideways to catch it.
This summer I had the cluster off and I ended up replacing the printed circuit board and the IVR. The IVR had failed a few months back and my fuel, oil pressure and temp gauges all peaked far right. Right now my oil pressure and temp gauges are reading normal so I don't know if the IVR can fail just one gauge.
Does anybody have any suggestions on how to troubleshoot this?
