I've just decoded a german Cobra ( @FoxChassis: thank you again for your decoders! Could you please check/correct the door tag info?).
I wonder what the door tag code "Int Trim - RA" means: ....????....(R), Black interior trim color (A). Leather, vinyl ?
Thank you for your help. I hope I'll can post some pics of tags and car later...
VIN
9F03F319172
9 - 1979 model year
F - Dearborn Assembly
03 - Mustang 3-dr hatchback
F - 5.0L V8 engine
319172 - 219,172nd 1979 Ford scheduled for production at Dearborn Assembly
buck tag:
MUSTANG = Mustang model line
319172 = 219,172nd 1979 Ford scheduled for production at Dearborn Assembly
61R = Mustang 3-dr hatchback
F = 5.0L V8 engine
0989 = body & paint rotations #0989
2P = Bright Red exterior paint color
A = Black interior trim color
DF
TT = Black lower exterior paint color (lower tu-tone)
ST
M
RW = rear washer/wiper
DRM = dual remote mirrors
EX = export
CBR = Cobra package model/trim level
WQM
3 = forward-facing non-functional hood scoop
V = visibility (light group)
2
DCR
door tag:
Date - 08/79 = .....(June or) August 1979 scheduled build
(or is it 06/79? )
GVWR: - 3871 LB - 1755 KG = gross vehicle weight rating
Front GAWR 2074 lb/940 kg = front gross axle weight rating
Rear GAWR 1817 lb/824 kg = rear gross axle weight rating
F0110 = 110 lbs front accessory reserve load
R0017 = 17 lbs rear accessory reserve load
Ext. Paint Colors - 2P = Bright Red exterior paint color
DSO - 91 = Export district sales office
Body - 61R = Mustang 3-dr hatchback
VR - [blank] = no vinyl roof
MLDG - 90V = Black bodyside molding w/ Light Orange tape stripe insert
Int Trim - RA = ....????....(R), Black interior trim color (A)
A/C - [blank] = no A/C
R - 7 = AM/FM stereo cassette (correct for 1979 ??)
S - [blank] = no sunroof
Ax - B = 2.47 Standard Axle Ratio conventional (non-limited slip) differential
Tr - W = C-4 Cruise-O-Matic Transmission
KK = front springs
MM = rear springs (MM = D9BZ-5560-P rear coil springs)
Btw:
is this correct?
