Yes. It does look like a potential point of resistance, which could cause the solenoid to jump in and out. Could contribute to it sticking.
Simpler to replace than test. To test it set your VOM to DC voltage and place a lead on each opposite side of the connection, then have a helper turn the key. More than tiny fraction of a volt on the meter will indicate excess resistance at the tested point.
