Results 1 to 17 of 17
    Jun 2003
    Santa Maria Ca
    Default 85 Seat refresh, foam only?
    My 85 GT seats are dirty, but otherwise in good shape upholstery wise. It does seem to have some foam degradation however. I’m thinking about taking the seats apart, cleaning the upholstery really good, and replacing the foam only with the TMI foam.
    Anybody ever done just foam? How was the end result?
    Thanks!
    85 Saleen Mustang(s)
    I don't see why you couldn't do that.
    I replaced my upholstery one year and then one or two later did the foam.
    FEP Super Member
    May 2003
    Roseburg Oregon
    I have had the foam spring mostly back to shape , after power washing and Super Clean .
    The dirt and stuff , seeps thru the fabric , and into the foam .
    After a good wash that crap is gone , and the foam fluffs back up .worth a try .
    Jul 2010
    Houston (Clear Lake), Texas
    My drivers seat foam was purdy settled when I was restoring the car a few years back. I bought new leather skins and foam for the drivers side. My wife sat in it and stated she would ride more if I additionally replaced the passenger side foam. It really is that much more comfortable after I tried it out, so both front seats got new foam. On a convertible you have to make some adjustments but all done now. Also, I cleaned up the front seat frames, springs, bushings, etc. There is a plastic bushing at the hinge on both seats towards the center console that was in rough shape. I found a brass unit that fit perfectly at Home Depot that will keep the upper seat tight and last for years.
    HAD
    HAVE
    Jun 2003
    Santa Maria Ca
    Superclean is the way to go. That’s what I clean loose covers with.
    Good tip on the brass bushing. I’ll look for that.
    Check the wire hammock on the bottom closely. Look for missing springs too. This will cause it to sag. I did hammock, springs and foam on my 89 with the old leather. Much better after. Unfortunately they don’t make vert. Seat back foam for 89 so my guy added some foam to the seat back.
    Quote Originally Posted by BaconB8 View Post
    Thanks!
    I did this a couple years ago. Pulled off the factory seat covers and replaced the dried out and beat down foam. Put the OEM covers right back over them with new foam and you couldn't even tell. No worries if your covers are in good shape. Mine were not dirty though. The cover was perfect but you could feel metal sticking up through the 30 year old foam. I didn't want to risk tearing the OEM fabric.
    Never owned a '89 Vert so I am just asking. What makes you think they don't make '89 sport seat foam for a Vert? There are certainly several parts of an '89 sport seat that are different between a hatch and Vert without question. But at the end of the day, the 'Vert and Hatch sport seat foam IS the same. There may be different holes cut in it but you will never convince me the foam won't work. The seats are identical outside of some seat belt attachment differences.
    The vert seat back foam has a metal insert to attach the seat belt loop. No one makes a reproduction for this. Therefore they are NOT the same.
    Jul 2010
    Yes, the oem vert seat back foam has a heavy metal wire that runs the perimeter inside the foam with an attaching plate for the seat belt holder. With the new foam there is not a way to attach the seat belt holder because it is just foam...like the other non vert cars. However, I wanted the factory look so I fabricated an attachment plate so the seat belt holder remained in the same location.
    HAD
    HAVE
    Got it. So the foam itself is the same but the factory 'Vert foam had a piece inside of it for the belts, making it unique. I understand now. Technically the foam would FIT the seat frame without an issue but I get what you are saying. Let's face it, if the metal piece removes when you remove the foam, it ain't doing much as far as safety goes. I don't believe seat foam does much for structural integrity. I would guess that's why they don't reproduce it like that. bwguardian's solution sounds like a good one.
    I did the foam replacement with the old leather. The leather was intact but not in great visual condition. The end result was a comfortable seat but it did look over stuffed at the edges. Now a few years later, I need to replace the leather. Best to do it all at once.
    In response to KevinK, you can actually buy leather covers that match OEM. Or if not EXACT, certainly close enough to pass as original. The issue with the 83-86 cloth sport seats is TMI spent all that time and money designing and building replacements but then cheaped out and selected completely the wrong material for ALL of them. So if you have a nice cloth seat fabric in all 3 seats and only the driver's seat foam is wasted, it makes no sense (money or common sense) to throw all that irreplaceable upholstery in the dumpster. If I had had leather or vinyl, I completely agree with your statement about "best to do it all at once"
    Seal the foam inside a plastic bag and pull as much air out as you can with your best shop vac for about 10 min. When you release it the foam will be about as big as it’s ever going to get......
    I did not see anything in the original post about irreplaceable upholstery. The foam is not cheap, add installation labor, the cheap job was not so cheap. Adding $800 for new leather seemed out of my budget.
    Fast forward, to today, I need to invest in new leather and pay for labor second time. Thus the reason for my comment. I also use my 89 as a daily driver often.
    Jul 2010
    The metal rod is embedded and/or molded within the foam backing. It only serves as a mounting point for the seat belt hanger. The seat belts have the 3 point mounting points for safety.
    HAD
    HAVE
    FEP Power Member Puter's Avatar
    Dec 2002
    Huntsville, Alabama
    I've ordered new foam, springs, and material for my 85 convertible. Do you have any pics of what you fabricated and how you did it?
    85 GT convertible
