![Quote](images/tf_ideal/blue/misc/quote_icon.png)
Originally Posted by
Mustang-junky
I'm selling my all fox mustang stuff. Some if the things I'd be willing to ship, other stuff pick up only. I can text pictures of things if you want. Prices are pretty low, but I will consider best offers. I'm located in Rome NY.
460 Swap into fox mustang headers, 2" primaries.
Motor plate. $300.
CSI electric water pump $100.
460 stud girdle with polylocks $25.
351w shorty swap headers, $50.
351w Ford motorsports intake, just like Victor Jr., $50.
351w ProComp Single plane EFI intake with elbow, $150.
351w rear sump swap Ford Motorsports oil pan and oil pickup, NEW, $75.
Windsor Sr. heads, ported, bare, fits 2.02" int. and 1.60" exh valves, $300.
Comp Cams XE282HR cam, Hydraulic roller, 232 int, 240 exh @.050 lift, $75.
Custom turbo cam, 221 int, 230 exh at .050" lift, .554" int .526" exh lift, Lobe seperation 116, $75
302 or 351 timing covers, I have three, $20 each.
302 oil pump pickups, $5 each.
302 351w chrome valve covers, $20
1.6 aluminum roller rockers, $50.
76mm C&L mass air meter with tubes for 42#, 24#, and 19# injectors, $50.
75mm P-Mass mass air meter, calibrated for 42# injectors, with flow sheet,
silicon connector and clamps, $75.
75mm Pro Products EGR throttle body spacer, $25.
5.0 EFI fuel rail with Adjustable Fuel Pressure regulator, and gauge adapter, $50.
1990 5.0 mustang EFI wiring $20.
11" C-4 torque converter, 3000 stall, 10.5" bolt pattern, $50.
9 1/2" C-4 torque converter, 3200 stall, billet cover, anti balloon plate, $200.
J.W. Ultrabell blow proof SFI C-4 bellhousing, $100.
T-5 bellhousings $25.
Double hump transmission crossmembers, $10 each.
Boxed stock Upper Control arms, $10.
1987-93 Coupe quarter windows, $20.
Maximum Motorsports Strut tower brace, $50.
3.73 8.8 rear end gears, $50.
2.73 8.8 rear end gears, $30.
31 spline Track lock 8.8 rear differential, with gear setup and rebuild stuff, $75.
1995-04 front control arms, with poly bushings, and Steeda ball joints, $75.
1979-82 taillights, one damaged, $10.
1983-86 taillights, $25.
1987-93 taillights, $25.
Hatch privacy shade, grey, $20.
1987-1993 fuel level sender, NEW, $25.
1987-93 gauge cluster, 140mph, $25.
1979 fuel filler neck, might fit other years too, $20.
4 fox mustang Throttle cables, assorted lengths, $20.
Seat brackets, $20.
5.0 rear springs, $20.
5.0 front springs, $20.
5.0 street/strip front springs, one coil cut, $25.
Door moldings, 85-86, and 87-93, $20 a set.
Cowl gauge holder, $10.
8.8 Moser 31 spline Lincoln Mark 7/ SVO length forged axles, 5 lug, with studs, NEW in box, $150.
8.8 Superior 31 spline, 5 lug, stock Fox length, with New bearing and seals, NEW axles, $200.
5.0 engine accessory brackets,
2.3 Garrett turbos, 60A/R comp, .63 A/R exh., $50 for the pair.
Jess
