Results 1 to 5 of 5
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Steering Coupler, Fender Vent Tubes
    I have 2 stock Steering Column Couplers for sale - $25 each plus shipping
    I have a pair of vent tubes for carbureted 1985 and earlier V8 cars - $25 plus shipping for the pair
    Interested in the inner fender tubes. PM sent.
    One of them tubes appears to be missing part of what sticks into the engine bay...
    Cheers,
    Jeff Cook
    Interested in thr steering column couplers
    Sent from my SM-G920V using Tapatalk
    May 2017
    Beaverton, Oregon
    Fender Tubes are SOLD!
