What's the piece called that sits at the bottom edge of the front side windows on the doors? It's a chrome piece and it has tabs that sit in holes on the top edge of the door.
It sits right next to the outer window seal/dew wipe on the flat spot before the panel makes the 60* bend downward.
My right side one is missing and I've just started searching for it online.
No luck using search terms that are: trim...body trim...chrome window trim....door trim...moldings....etc.
I can try and put up some pics if that will be helpful.
There's something for 87-93 called outer belt moldings but nothing for 79.
