Page 17 of 28 FirstFirst ... 7151617181927 ... LastLast
Results 401 to 425 of 698
  1. #401
    Default replaced washer fluid pump
    Washer fluid pump quit working.
    Checked connections with test light. OK.
    Bought new 4.00 pump ele pigtail from NPD.
    Replaced pump with new Trico #11-506 Superpump for 13.00, in stock at O'Reilleys.
    Made in USA.
    Took tank completely out. Cleaned tank with Simple Green.
    Emptied and discarded coolant from the coolant tank side. Dirt was on the bottom.
    Prob gets in from the gap at the overflow hose opening.
    Removed old retaining ring.
    Old pump is hard to get out and have to be careful not to crack tank when prying.
    Pulling on the pump ele connector walls only cracked off the plastic.
    Pulling on one of the pin connectors with channel locks popped it out.
    Old pump did not spin freely like the new one. Started to rust.
    Lubed new pump seal with powdered graphite per instructions.
    Installed the new retainer which fell into the grass.
    Installed and connected new pigtail.
    Filled with plain water to check for leaks and operation. OK.
    Topped off with washer fluid and fresh coolant on the other side.
    Works great. Took one hour.
  2. #402
    Changed out the pbr calibers on monday and added stainless steel brake lines.
    now all i need is new inspection and i can take her to work.
    1982 Mustang coupe with 66 mustang 289(30 over, keith black pistons,etc.) 4cyl world class t-5, 8.8 with 3.55.
    1980 Mustang hatch(sold)
    1965 Mustang (in process)
  3. #403
    Pulling out my gas tank for the bazillionth and I hope to God LAST time. Putting a boatload of new parts on to address my fuel vapor smell problem. If this doesn't fix it, the car may go off a cliff.
  4. #404
    FEP Power Member bluesfannoz's Avatar
    Aug 2007
    Lawrence, Ks
    Replaced the bad wiring on the voltage regulator connection. As you can see it has shorted out previously! Scary!
    Here is what it looks like now:
    Steve
    "Taillights in Your Face Jack? You've just been Dominated!"
    # Link to Facebook Dominator Mustang Fans # # Link to Facebook Predator Mustang Fans #
    # Link to Facebook Twister Mustang Fans #
    Current Stangs: Stangless
    Previously owned:
    84 Black GT, 85 Black T-Top Dominator GT # Link to Restoration Thread # 85 Dominator GT RIP 1995, 85 Predator GT, 83 Dominator GT, 82 Mustang GT
  5. #405
    Quote Originally Posted by bluesfannoz View Post
    where did you get the pigtail for the voltage regulator , i need one!!!
  6. #406
    Aug 2007
    Lawrence, Ks
    I ordered this one. I also got a tool to be able to remove the wires, so I ended up using the new wires with my original connector so I could stay with the grey connector. But the red one that comes with this is correct. I did not need all six wires it comes with.
    http://www.repairconnector.com/produ...-75-to-89.html
    The tool I used came in this set(Center one in Picture):
    http://www.repairconnector.com/weath...-set-3-pieces/
    Hope this helps!
    Quote Originally Posted by Mousemate View Post
    Steve
    Previously owned:
  7. #407
    FEP Senior Member 86gtstang's Avatar
    Jan 2009
    Chester,SC
    I put it back in the garage yesterday and started sanding on it again
    Robert
    86 GT vert
    85 GT
  8. #408
    Jan 2006
    Western MA
    Last night I completed phase 2 of my "quiet the exhaust" project on my 86 vert. Car is mainly stock with the exception of flow masters and 2.5" tail pipes, even has the smog equipment including the factory stock catted h-pipe.
    The car failed state inspection a few weeks back due to being "too loud". Results next week when I take it back for re-inspection....
  9. #409
    Mar 2014
    Omaha, NE
    That has to be one of the dumbest things I have heard in a while........I could see not passing smog but not passing cause someone didn't like the sound of it, unless it was straight piped I guess
    Brock
  10. #410
    Jan 2006
    Western MA
    Don't even get me started about the "issue" here in Mass. This car passed state inspection for the last several years from the same inspection station with no changes to the car whatsoever. The old tech retired and the new one feels the car is too loud.
    Bunch of BS - but at lease I do have a plan.
  11. #411
    Jan 2011
    China Grove, North Carolina
    From what a friend of mine and I have noticed, the same mufflers on the same car but with different diameter systems, the 2 1/2" was quieter than the 2 1/4". I guess your inspection station is like customer service, it all depends on who you get the day you call as to what they can do for you.
  12. #412
    FEP Senior Member BlackMamba's Avatar
    Aug 2012
    Los Angeles, CA
    Installed my Windshield Decal
    Current Cars:
    1979 Mustang Ghia Coupe 5.0 3J Bright Blue
    1984 GT T top 306 5 speed "Black Mamba"
    1986 Saleen Black with Silver Stripes 86#009
    1986 Mustang GT Medium Canyon Red 5 speed 5.0
    1999 Mustang GT Convertible 35th anniversary 69K miles.
    2002 Nissan Maxima 6 Speed "Daily Driver"
    2009 Corvette 6 speed LS3
    1998 Cobra 71k miles Canary Yellow "Nana" SOLD
  13. #413
    C'mon Mamba, how about a full shot of the new decal with the whole front end visible? Fans of 86-0009 deserve better. Lol
    Cheers!
    Mike (TopGear85)
    Have:
    Had:
    79PC-San Jose #2890
    90GT-Oxford Wht,5spd
  14. #414
    thank you i will order have to order one up.
  15. #415
    Hope this helps!
    sorry for the double post
    but thank you bluesfannoz
    for the info i will order one up
  16. #416
    Mar 2014
    Omaha, NE
    Good to have a backup plan! Glad I live in a state that does a lot of things wrong and backwards but at least they don't have any emission testing standards
    Brock
  17. #417
    Aug 2012
    Los Angeles, CA
    Quote Originally Posted by TopGear85 View Post
    Haha, pretty soon I'll get some good pictures of the whole car and post them up.
    Current Cars:
  18. #418
    can you go to another inspection station?
    i had the same thing with my 84 s-10 would not pass.
    took to another station no problem.
  19. #419
    Jan 2006
    Western MA
    I've got 60 days to "fix" the problem. Then I can take the car back to the same station for a free re-inspection. Waiting until next week since it's the start of a new month, next year it will need re-inspection also in Aug. Otherwise it's $35 bucks down the toilet.
    If I go to another station (especially too quickly) and get a sticker, it could throw a flag in the system.....
    1986 SVO Mustang - 1C
  20. #420
    Feb 2009
    Snohomish, Wa
    My state has a louder than stock law. Fortunately, cars 25+ yrs old are exempt from it and emissions. All I have to worry about is meeting the legal noise level.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
  21. #421
    Wow that's defiantly harder then pa. I guess this is another reason I am not moving out of pa.
  22. #422
    New User 5.0vert's Avatar
    Aug 2014
    Edmonton alberta canada
    Ya ya I know this is a hard one today, I removed the mudflaps from p.o.....I don't care for the rims but the tires are all new and should burn off nicely I picked up a set of 17" rims n rubber for it so these are just for the build I guessName:  image.jpg
Size:  95.8 KB and these would be the new rims Name:  image.jpg
  23. #423
    Aug 2014
    Default Hmmm... Wtf!!
    Look at this beautiful disaster I bought Name:  image.jpg
Size:  125.3 KBName:  image.jpg
  24. #424
    Mar 2014
    Omaha, NE
    Quote Originally Posted by 5.0vert View Post
    Nice!
    Brock
  25. #425
    Mar 2014
    Omaha, NE
    I dropped (literally) the fuel tank of the Vert today to get ready to replace all of the dry rotted gasketing and check the in tank pump and sending unit. After it slid off of the jack i was using to stabilize it, dumping a 1/4 tank of whiskey colored gas all over myself and the garage it soon became apparent it just turned into a bigger job than expected as it has some internal corrosion and tons of varnish in it that needs to be addressed.
    Brock
