Looks Great!
Now for the fun of making both sides match!
Trey
Looks Great!
Trey
Trey
Been there, done that. Not fun. As I cut and fit the first side, I cut and ground the second side pieces at the same time. Not a guarantee, but it helps. What I am not looking forward to is getting all of these welds and edges straight, and keeping the body lines crisp on the new pieces. I then have to rip it all back off, coat the back, jamb the car, re install them with seam sealer, and hope it all still lines up.
You could probably make some SVO style spats with less difficulty. I bet folks would buy them if they were available.
Jess
Previously owned;
That's a good way to do it to help things match. I know in my experience that getting both sides identical is always the most frustrating, so I feel your pain!
Just keep in mind how awesome it will look when you get it all done and painted and that will keep you motivated to get it all done!
Trey
Trey
Not to steal work from Brian if he wants it, but the SVO style spats are reproduced in fiberglass.
Here is a link to them. http://www.svpu.com/ccart/index.php?...&product_id=47
Trey
Trey
Ahh, but I could make them for cars that do not have the rocker moldings!![]()
Steel ones could be welded on and blended in real nice.
Jess
Previously owned;
I would install those large fogs like the bug eye impreza and 2.5 rs came with. Maybe some small canards.
Brian, how much weight do you figure your adding to the car?
Dave
1983 Capri RS Turbo
1981 Black Magic 400 c6
93 F-250 351 5sp 4x4
A full 4x8 sheet of 22GA steel is around 30LB. 60' of 1/8×1/2 strip and 60' of 1"×1/8 was 42LB. Minus the scrap, plus the body filler, probably around 70LB. for the whole thing.
Nice! The weights not bad either. Hell that's about the weight savings of a K-Member.
Yep, or removing the jack and spare. I swore I had, and when I pulled out the interior, I had not. I wish I had gotten a couple of runs in without the jack, spare, and rear seat, with drag radials. Bet I would have hit twelves.
Not bad. You're doing an awesome job as well.![]()
Dave
1983 Capri RS Turbo
Wow, Brian, great work! I wish I was there to see it (kinda). You'll have to take it on a short drive down 95 to visit when it's done!
Looks great Brian. That has to be a good feeling knowing you are doing that yourself.
Love it man. Wished I could do this kinda stuff. I think the front would look even more sweet if it had more of a splitter look kinda like the cobra splitter. I mean with just that little piece added to the very bottom to make it stick out.
Been working a ton with the bad weather around here- It has been difficult to get anything done. I did get the last side skirt finished.
I have the framework for the rear valance roughed in. Not sure I am in love with it, but I will have to see. It is hard to capture how it looks in a picture, since it is so two dimensional, but you get the idea. It follows the line of the bumper cover exactly.
looks great, keep us updated.
Looking pretty cool!
Trey
Trey
Keep those pictures coming! Very interesting!
1982 Dominator GT
*1st Dominator ever sold and
autographed by Jackie Stewart *
1993 Corvette
2005 Roush Mustang
2008 Escape (DD)
Looks great, keep going!
