.Our NEW, patent pending PRO-Series™ suspension system, here are some key bullet points:
· SLA (Short & Long Arm) / Double wishbone design replaces inferior strut suspension on
1979 and newer Mustangs
· CAD/ CAM Designed and modeled using SolidWorks 2007
· Design F.E.A. (Finite Element Analysis) Confirmed using COSMOSWorks 2007
· CNC Machined out of 6061 T6 Billet Aluminum
· All geometry optimized for unsurpassed handling and performance
· Zero Bump steer
· Tested and proven on the race track
· Modular construction
· Center section of K-member removable for access to remove oil pan without need to remove engine or k-member
· Wheel track and width adjustable for race application
· 3/8” drive adjusters on control arms make alignment adjustments easy
· Spindles incorporate a 2 inch drop in ride height to maintain proper suspension geometry
· Spindles have caster already built in for better stability
· Available in traditional upright shock or cantilever pushrod design as an option for ease of tuning on track
· 3 position Adjustable anti-roll bar provides a wide range of adjustability
· Self Lubricating spherical bearings require no maintenance
· Can accommodate any caliper combination
· Uses off the shelf Fox or SN95 Mustang rack-n-pinion steering rack
· Wide range of shocks available to suit customer’s needs
