This thread is more about the gaskets that go under the trim...mine are shot.
I've looked all over without luck, and I'm sure that the ones sold by FMR come without the rubber seals.
Does anyone know where I can buy these?
Thanks.
Thanks.
Original Member of 'The Anti-Cowl Hood Club' and 'The Ten-Hole Mafia'.
I need those too.
Looks like this Hockey stick seals are one more part to add to the list of NON EXISTENT
Anyone else got a clue where to get these?
The 83-86 are not being made. The 87-93 are being remade. The shape is the same because the 1/4 panel is the same. I have had customers in the past use the 87-93 gaskets on their earlier car. I believe you have to trim the front and add a few holes for the mounting studs. But once installed they look the same.
That's good to know because the 86 vert I just bought needs them
Robert
86 GT vert
85 GT
I'm not sure exactly which part that is but here are the trim pieces I see for the verts:
Side Quarter Rear Patch Pad:
E3ZZ 7652858A RH
E3ZZ 7652859A LH
Qtys:
38 - RH
40 - LH
COLLECTORS AUTO SUPPLY
OROVILLE, WA 98844
(800) 414-4462
Folding Top Stay Pad Case - Rear
E3ZZ 7652874A RH
E3ZZ 7652875A LH
Qtys
2 - RH
1 - LH
GREEN SALES
CINCINNATI, OH 45237
(800) 543-4959
Convertible Top Side - Front Patch
E3ZZ 7653478A RH
E3ZZ 7653479A LH
Qtys:
29 - RH
45 - LH
OROVILLE, WA 98844
(800) 414-4462
Rear Bow at Corner Pad Assy.
E3ZZ 76537A70A RH
E3ZZ 76537A71A LH
Qtys
1 - RH
0 - LH
PARTS INTERNATIONAL
FARMERS BRANCH, TX 75234
(888 ) 727-0418
E3ZZ 7654212A RH
E3ZZ 7654213A LH
Qtys
3 - RH
3 - LH
GREEN SALES
001 (800) 543-4959
I finally got the hockey sticks and a new rubber gaskets.
But I can't figure out how to go about replacing it
What are the steps?
Anyone done this before?
Anyone?
I looked at them when I just had the top redone on my 85 and could not figure out how they come off. I suspect the hinges off the trunk are partially holding them on and I need to remove those before mine goes to paint as I have some like new ones to put back on.
The moldings should have studs on the bottom, which bolt to the quarter panel. Below is a scan of page 53 of the Convertible Service Manual. You can see where the three studs attach (near the quarter panel edge) and the screw is. The studs should have nuts that are accessible from within the back seat area after you take out the interior trim panels and well lining.
Thanks eeprete, that's just what i needed!
Now I need for the temps to drop some here in TX, before I can tackle this project
Ok, following up on this thread here a little bit.....
I'd like to thank all the guys that chimed in with different input.
So here it is, now that I finally got around to it.
Yep! 87-93 gaskets... and 87-93 moldings believe it or not, everything worked just fine.
The gaskets do need to be sniped about an inch at the front , and the molding has a tab at the front that also needs to be clipped away, but other than that is pretty straight forward.
Thanks again..
Edit: The moldings are pre '86, not 87-93 like I stated before. My bad
Thought I'd clear that out before somebody goes out and gets the wrong parts.
