David LaRoques book on the SVO states that after Feb 29, 1984 when most of the options were made standard to delete them, option 41 removed them as Competition Prep option. You will notice on the sticker there was a $1200 credit to delete these Items. The car you are looking at was built a couple of months after this date. I have found several over the years and this has been correct on the cars I have found.
I have not seen on a build sheet or buck tag that says anything about wheather it is a comp prep or not. Only thing for sure is the Eminger reports from Marti Auto works or the oringnal window sticker. The one I printed above the vin is 17xxx so the one you are looking at is well above that. And yes I know cars are not built in exact order of the vin numbers but this works out. I also have access to the build dates. At the moment I have 11 Comp prep svo's. Hope this helps. later Kendal
