Results 1 to 19 of 19
    Default 8.8 or IRS set-up, Decisions
    Okay guy’s, I’m trying to decide which route to take or if in any. My ’82 GT is stock 4 lug with the original 7.5 rear. I plan on building the motor, so I’m pretty sure the 7.5 along with the 4-lug will have to go. So here is my question, my options; go with the 8.8 rear and 5-lug disc all around conversion or go with a ’03 Cobra IRS and SN95 5-lug disc front (undecided on front Susp. If using the IRS). What I plan on doing with the car when it’s finished; it would not be a daily driver, it will be worthy of being entered into a car show but NOT a show car per-say, it will not be a drag car but I may take it to the local track a few times a year just for FUN, it will mainly be driven on short cruises on back roads and day trips with the wifey on the Blue Ridge Parkway, and I could see some track days at many road course’s. I prefer for the car to handle great around corners as I like to drive them a lot more then going straight. As far as looks go, I like the wide stance look but don’t like for the tires to stick outside the fender lip. I would like to use a 10” rear or at least a 9”, I’m not even sure if that would be possible with the IRS…???... Please give me some feed back on what you guys think, and any pictures of any set-ups you might run. I really want the car to handle good but the stance and look have to be right too!!
    FEP Power Member In2Fords's Avatar
    Mar 2009
    Honolulu, Hawaii
    I personally think the only reason to go 5 lug is for better rim choices. I have seen 11-12 second cars on 4 lug. You would have to be making some serious power to shear off the lugs.
    As far as axle, I would stick with a 8.8, if you were going to be doing extensive road tracks then i could see going thru all the trouble of doing a IRS, but not for weekend track fun days. I have been in a couple foxes converted to IRS, seemed better in the corners then my solid axles cars but it wasnt that much softer of a ride and suspension tuning was intense to try to get it to grip on launches, of course that could have just been how the IRS was put in.
    I would build the car with a cheap 8.8, WELD THE TUBES, then after it is complete IF you feel a IRS would be needed takle it then. Nothing like tearing into a huge project then losing steam and finding something allready together to kill a project. Take baby steps
    Good luck man.
    FEP Power Member RichV's Avatar
    Aug 2003
    Elizabeth, Colorado
    An IRS is arguably better on a roadcourse. So either one would sujffice plenty for a fun driver. 5 lug will definitely have more wheels as options. Also, the 5 lug route is easier for cheap brake options.
    85 SVO
    94 GT CMC#71
    65 Fastback
    Aug 2004
    California
    Been living with an IRS 01 Cobra since new. Rides a bunch better than a stick axle. BUT, leaves alot to be corrected in the handling depertment in stock trim. Tends to squat during acceleration which causes the wheels to go negative camber reducing the contact patch to the inside edges = tire spin. In turns, different forces cause the same thing. This IRS has the 31 spline shafts but the weak-link are the stubs which break if too much power is put to them. This usually occurs during axle tramp which a stock IRS does exceedingly well. Now, all this can be corrected with cubic money, but then you lose what the IRS does best - rides nicely. Also, the IRS cradle is pretty wide which means wheel-width choices when in a fox body will be limited. I'd do an 8.8 stick axle and throw the entire spectrum of MM or Griggs parts at it. The result will be a less complicated system, better handling for less money, and your choice of rim-widths up to 10" or so.
    If your plans are not road course racing, the 8.8 will more than be sufficient. Like mentioned previously, the Griggs systems are the best and the you could use the money for the IRS to pay for most of it. With the GR40 system, there won't be too many cars that will be able to out handle yours.
    Guys, thanks for the advice! I'm going to look into the Griggs/ GR40 system, I've never heard of it before. I would love to know/learn more about it, if you could go into some detail on it or post some links for related info.
    Aug 2003
    Elizabeth, Colorado
    Get ready for a wallet beating.
    85 SVO
    94 GT CMC#71
    65 Fastback
    FEP Member willrst's Avatar
    Apr 2010
    Tulsa-ish (Inola) OK
    Quote Originally Posted by qtrracer View Post
    So your saying its not worth it for a DD. Oh and if you dont mind what about dose it cost to put an IRS in a fox?? Im wanting to do it. and do you have any pics? Thinks...
    2004 gmc rst.
    1996 gt for my DD
    1986 notchback in the works... doing a 4.6 5speed swap..
    Will
    Default IRS in 82
    Quote Originally Posted by willrst View Post
    I just got finished with my car doing exactly what you are thinking about doing. I can answer everything you might have questions about. Just hit me up.....I have not adjusted the coilovers at all corners yet, that's why it's sitting nose high..... and I can take more IRS pics if you need them, just tell me what you want to see......
    Who has pic's of their set up, 8.8, 9", IRS, or Griggs? Choice of Control arms, springs etc?? Would like to see your car's set-up/stance and wheel size options!
    Jun 2007
    Sunny Arizona
    Default Dont forget about...
    Maximum Motorsports!! I am not a fan of Griggs. Too many times I spoke with them and they were anything but friendly. I actually wasted a very pretty penny on their sway bar (against my better judgment but they were the only ones I knew of with that type) for my Modular 82 GT project which wouldn't work so I had to sell it at a big loss. I waited weeks for them to send me the correct hardware too. I just don't have anything good to say...except they do have some nice stuff. Not necessarily better than MM. Its kinda like Ford vs. Chevy. Both have good and bad.
    FWIW...I too have the IRS in my 82 with MM coilovers and bone stock IRS otherwise. I LOVE the way it rides and handles. It used to beat me to death with the solid axle. I wouldn't hesitate to do it again given the chance. Of course, I don't take my handling too serious as in racing of any kind. Its a fun car that I drive occasionally. And I believe you could easily run a 9" wheel given the correct offset. I'm just not sure what that is since I have never tried. I am using 05 GT wheels.
    Jun 2007
    Sunny Arizona
    Quote Originally Posted by JOEFIVEOH View Post
    Default wheels
    Quote Originally Posted by 73z-6sp View Post
    Are those 17's off an 06 gt....
    Aug 2003
    Elizabeth, Colorado
    That sounds like a fun project. The 82 looks sweet with those S197 wheels. OT, why did the modular swap not work?
    85 SVO
    94 GT CMC#71
    65 Fastback
    I went with a built up .045 over 351w/69 block..Just a little old school.....
    Jun 2007
    Sunny Arizona
    The wheels are from an 05. Probably the same as 06. Not sure.
    It wasnt the mod conversion that wouldnt work...it was the sway bar. With my new suspension, it hit the wheels and severely limited my turning radius. The mod engine is awesome!
    Jun 2007
    Sunny Arizona
    Quote Originally Posted by halffast82 View Post
    Nice!
    Banned
    Feb 2009
    Goldsboro/Pikeville, NC
    my friends 275 drag radial class car runs 4 lug and its expected to go in the 4's in the 8th mile with the new setup....
    my 82 has a 5 lug conversion which give me more wheel choices and way better brakes...im planning on doing the IRS swap since i dont plan on running my car at the strip more than a few time a month
    Joe,
    Here is a link to our Torque Arm tech page for solid axle 8.8 applications:
    http://www.maximummotorsports.com/st...h_rear_susp_ta
    Here is a link to a write up comparing the IRS performance to the performance of the solid axle 8.8 with a TA and PHB.
    http://www.maximummotorsports.com/st..._irs_faq_royce
    The solid axle has an advantage in forward grip from a dead stop, due to the greater amount of antisquat. The IRS has a significant advantage in ride quality due to the much lower unsprung weight.
    When you install both rear suspensions with all of the fixes, the overall cost ends up being about the same, depending on what options you use. If you have any specific questions, just ask.
