Hey everyone, the time has come. After driving my Cobra for the past 6 years and installing a brand new Air Conditioning system two years ago, I've decided to finally get off of my lazy butt and wire it up.
First, a little background on the situation. Nine years ago, I removed the original drive train, which consisted of the 2.3 Turbo/4-speed combination. My brother and I were careful to NOT cut any of the original wiring or throw any of it away. I also took all of the wiring from the engine upon removal. We've since replaced the drive train with a 302/5-speed combo and all has been fine thus far.
Two years ago, I purchased a lot of brand new A/C accessories for a 1990 Mustang LX with the 5.0/5-speed combo from Advance Auto Parts. Total cost was somewhere around $400.00 but it will be well worth it - should I be able to make it work! I installed the entire system which consisted of a brand new Evaporator Core, Accumulator (Receiver/Dryer), Condenser, and hoses. My brother had an extra pressure switch and pump that were in good working condition, so I will be using those. From the outside, it appears like I have a factory fresh installation and a working system - until you look at the wiring, which isn't hooked up to the pump yet. Here's a pic.
Fast forward to tonight and this is where I've started. I've got all of the plastic corrugated tubing and Black electrical tape removed from all of the wiring in the engine compartment and I've located what I think is the main wiring for the A/C pump (see both pic's below). It's on the passenger side and has a Bullet connector with a female end on it. If I remember from 9 years ago, the original pump had the male end on it but I'm not too sure. Also, there's some type of vacuum thingy attached to it. What is this and is it needed? Does this even go to the pump or is it something for the Turbocharger unit? I probed the Bullet connector with my test light and it did not light up. I then turned the key to the "On" position and moved the A/C control lever to the A/C position and turned the fan on. The test light still did not light.
I also have this as well (see pic below). What is this and what does it do? I know it connects to a female connector that I have on the passenger side of the radiator support but I'm not sure where it mounts, if I'll need it, or what it does.
As for the wiring itself, I have the 1979 Wiring Diagrams that I printed off of this site but they're very small and hard to read. I've tried to enlarge them and print the enlarged copies but have been unsuccessful thus far. I also have a Chilton's Manual and a Hayne's Manual and neither of them offer much of anything.
Any help is certainly appreciated!
