Results 1 to 25 of 50
    Default Under carb. heat shield ?
    Did Ford install the heat shield under the carb in 83 with the return of the 4v, or was the shield added in 84/85?
    FEP Member TMcG85GT's Avatar
    Mar 2006
    Turnersville, NJ
    I believe it did have one. Hang in, a lot of people smarter than me will clear ya up.
    Tim McG
    I've owned my '85 GT since '86.....I call THAT 4-eyed pride!
    Yes the 83 4v had one.
    It was revised for 1985.
    Not sure if earlier cars had it as well.
    -Mike
    FEP Power Member craigerSS's Avatar
    nova scotia
    i'll third that,mine's got it
    here's to the freakin' weekend,I'll drink to that
    The heat shield you are looking for is
    E5TZ 9S596-A 83/89 V8 Carburetor Heat Shield
    Older models had the following:
    E0SZ 9A462-A 80/82 V8 Carburetor Heat Shield
    You can use any 83,84, or 85 heat shield on your 83. Note that this heat shield is specific to 83-85 Mustangs and Capris. They were not used on any other vehicles, making it a pain in the neck to locate as many people have bent them to access various things (like idle jets), or they just tossed them during a carb swap.
    Thanks for the good information. Jerry.
    Quote Originally Posted by 85GTTops View Post
    Pretty sure they show up on trucks/vans too.
    -Mike
    FEP Super Member 83GTRAG's Avatar
    York, PA
    I took mine off...should In put it back on-changed to a edelbrock intake and a dual pump 670 street avenger carb?
    Quote Originally Posted by negusm View Post
    -Mike
    They do but they're slightly different. I don't recall what the differences are but the part number is very specific to the 83-85 Mustang/Capri's. It may have something to do with the shape. But as far as factory correctness is concerned, this is the only one.
    Neither of those part numbers suggest they were originally engineered specifically for
    a Mustang.
    Cheers,
    Jeff Cook
    80-82 models have a Thunderbird heat shield.
    The E5TZ part number for 83-85 models has no reference to any other vehicle as there is no "T" vehicle listed for 1985. There's not a T vehicle between 1980 and 1989 either.
    T = truck/van.
    Do you have the parts books for the Truck/Vans? I do not or I would look this up.
    -Mike
    T = truck/van.
    -Mike
    No I don't. I wish I had though. Let me root around and see if I can locate this part on a Truck model. It could be for a Bronco. If so, we will have found another source for these plates.
    I just did a search of the world's largest parts book for all Ford, Lincoln, and Mercury trucks and cars, and this part number is the only one and only applies to the Mustangs/Capri's.
    Now, that doesn't mean a part wasn't superseded. We'll need to find someone with both a 1985 car and 1985 truck catalog set to make sure.
    There are many parts that cross reference to truck's/vans. Everything from carbs to HVAC dash panels, emissions and steering column parts. Problem is, the part numbers seem to be reassigned so unles syou actually see the part you'll never know that the two part numbers reference the same part.
    -Mike
    Where did you search? Who'd you call?
    My buddies out in Russia. They have a site that has all the parts books online, for just about all the manufacturers.
    I'm calling Bret over at GSC soon and see if he can cross reference it.
    some one need one? got one! no not for free.
    Edel Perf intake & 600cfm carb & 6037 heads, non-roll eng 9.3comp,alignhone/torqueplate bore/balanced,cm filefit rings,recon rods&caps,10under crank,Clevite bearings&KB pistons,CompCam:dur 224I/224E@.050 lift/110,Crane alum1:6 RR,new8.8-373s.Granatelli upp/low cont arms,KYB adj.shocks,4 point K-member brace,B springs&ft cont.Arms,struttower brace,1 5/8 headers,weld subframe connectors.,10.5 clutch&flywheel,T-5Z/PRO5.0 shift.Canton7qt pan,bal shaft-Spicer u-joints.welded boxes.alum rad.MSD6AL&dizzy,17" Rs.276RWHP
    i just bought a intake E3 for my 83gt for 80 bucks came with matching heat sheild and egr. i guess i got lucky
    1983 Mustang gt-t-tops,5.0,4spd,all original
    1983 Mustang GT -sunroof 5.0 5sp, work in progress.
    2003 Cobra - 2.8 pulley, headers, o/r xpipe,flowmaster cat back, bf irs brace, h&r race springs, mmcc. SOLD
    2002 Mustang GT - Lt headers,o/r hpipe,slp2 catback,4.10 gears,cai, pro 5.0 shifter,sct2 tune. SOLD
    2001 Focus zx3 - Daily Driver
    1988 Bronco XLT - 5.0 -Sold
    1983 Mustang GT - (my first car) sunroof, 306,srod 4sp, 3.55 gears, Lt headers, o/r hpipe, flowmaster catback. SOLD
    I know this is an old thread, but it still comes up in Bing/Google searches when looking for the right part here, so I just wanted to note:
    E0SZ-9A462-A is a heat shield, but definitely not the under-carb one. I found one online (no pics), and when I got it, this is what it looks like:
    So, for anyone looking for the heat shield that goes between the EGR spacer and the carb, don't use that number.
    -- Brian
    Have:
    '01 Mustang Cobra
    '74 F-100
    Had:
    '84½ GT T-top
    '83 GT T-top
    '85 LX V6 Hatchback
    FEP Power Member 83gtstang's Avatar
    Shreveport LA
    My 83 came with one, still have it in the attic somewhere.
    Interested in getting rid of it? I'm building an engine for my '74 F-100 and using the carb setup from an '83-'85 four-eyed Mustang. I have the manifold, spacer, and carb, just not the heat shield.
    -- Brian
    Have:
    '01 Mustang Cobra
    '74 F-100
    Had:
    '84½ GT T-top
    '83 GT T-top
    '85 LX V6 Hatchback
    Please send a Private Message (PM) if you want to talk about buying a part. Thanks.
    Cheers!
    Mike (TopGear85)
    Have:
    Had:
    79PC-San Jose #2890
    90GT-Oxford Wht,5spd
    Dec 2002
    Greenville, SC
    Good info!
    1979 Mustang Cobra 5.0
    2P Red and 1C Black
    Stock never goes out of style
    Proverbs 3:5-6
    My Mustang Story
    Quote Originally Posted by bkaul View Post
    -thats a heat riser shield for the exhaust mainfold, L.H. side....should be to protect the rag joint.
    '87 Turbo Coupe - 660 mile original
    '86 Turbo Coupe - 74k mile stripper
