does anyone know a website that makes a full a pillar with gauge openings for an 84? I know there are many for the 87-93 stangs but i couldnt find a website that makes them for older foxbodies
thanks
thanks
1984 Mustang Coupe
302 h/c/i with t-5
thats too bad. they should make one for the older years
1984 Mustang Coupe
302 h/c/i with t-5
I just installed a 2 gauge pod on my 86 pillar,looks good,but then i saw the cowl grill with the pods and really like it.
86 GT,ALL STOCK
What's the difference between the 87 up A pillar and the 79-86?
Thanks.
Howard
I know on my 86 i had to lift the dash pad to get the a -pillar off because theres a screw you cant get to,on my 90 i just popped it off to mount the pod,basically its different at the bottom of the pillar itself.
86 GT,ALL STOCK
The full pillar Autometer makes will fit our cars but then you can't get the dash pad off w/o removing it! I had originally purchased one but realized this and had to get the add-on pillar instead. Too bad too cause it's slick.
=Mike=
86 AscMcLaren Capri #026/114 | 11.2@123
86 Mustang SVO - 9L | 14.0@97 | 19psi
My Website (New and Improved)
Custom Wheel Center Caps, Vinyl Decals Racing #'s etc.
o man that sucks. they look so good especially when the rest of the interior is in good condition. too bad
1984 Mustang Coupe
302 h/c/i with t-5
But they'll physically fit and look correct? If I have to remove the dashpad, I'll just have to remove the 2 top, clip-in, trim pieces that cover the headliner then remove the A pillar?
Thanks,
Howard
No, they won't physically fit because they'd interfere with the dash, being a different shape at that end. If you cut off the bottom, the rest would fit, but then you'd be missing part of your A-pillar ...
-- Brian
Have:
'01 Mustang Cobra
'74 F-100
Had:
'84½ GT T-top
'83 GT T-top
'85 LX V6 Hatchback
