I'm sure you guys have heard this before... but I am determined to get the factory tach to work without the 8910 tach adapter.
I have an 86 GT (TFI) with the new MSD 6AL-2. Love the 2 step!
Anyways, the tach stopped working, so I had the idea of disconnecting it at the tach and connecting the tach output wire directly to the tach. As you know, the same green wire on the negative side of the coil is what signaled the tach. Connecting the tach output wire like this will cause no spark or an erratic tach.
So I pulled the cluster and snipped the green wire on the back and ran the tach output wire to it, and it worked! Accurate too, matched perfectly with the 2 step rpm. Only problem is, now it cuts out at 4000RPM. I'm coming up with ideas with diodes and resistors to try and get it to work properly. I mean, what does the 8910 tach adapter really do?
Has anybody successfully wired the MSD output to the factory tach and got it to read properly and in its full range?
