Quote:
Originally Posted by theemustangman
If i am not mistaken that spring once the wheel is on keeps the correct pressure on the bearings in the shaft. and the only reason i think that is the column in my el camino i had had the same spring and after removing it the column bearings and other parts took a crap and i had to switch columns i think its the same for the Stangs IDK though
Quote:
Originally Posted by banzaibullitt
Hmmmm... interesting.
85GT-79FJ40 told me he removed the spring in 2006. He's put on about 30k miles since then and has had no problems.
Anyone else??
[IMG][/IMG]
I called the Ford Tech Line 800-3673-788. The engineer wasn't positive, but he thought the spring was there just to keep clearances in check.
I called Grant and they said that only the cruise control vehicles have the spring. They thought the spring was only there for vibration dampening.
The Grant tech said you must remove the spring because it interfers with the adapter. The Grant cruise control adapter instructions state this, but the #3289 instructions do not state this.
__________________
1979 hatch
