I just purchased FMR replacement dew wipes. I wanted to know if anyone could tell me how to remove my mirrors for the install. I don't know if it matters but my car is an 86GT vert. Any help would be appreciated.
To remove the mirrors:
- Open Door and leave open
- Locate triangle cover on the inside, this has the remote stick coming out of it, and is over mirror studs which you need to gain access to.
- Remove phillips screw
- Locate "small" set screw that holds the remote control for the mirror in place. (Small allen style set screw)
- Back off set screw, do not need to remove it completely.
- Slide triangle trim off mirror remote. If your remote stick has the rubber knob on the end, some do some don't, you will need to pull that off to slide the triangle plate off.
- Locate the 2 nuts behind that plate, remove them and be sure not to drop them inside the door. I don't remember the nut size at this time.
- Once nuts removed, pull mirror off the door from the outside.
I think it's a 10mm nut. One you get the mirrors off, start at one end and gently pull the dew wipe upwards with your hands working your way down to the opposite end.- Locate the 2 nuts behind that plate, remove them and be sure not to drop them inside the door. I don't remember the nut size at this time.
1979 Base Model Coupe- 351w, C4, 3.73s, the fun machine- Now getting a lot more well deserved mileage put on her!
2007 Forest River Sunseeker 2200 Class C motorhome on an E-450 chassis. Oh yeah!
2013 Subaru Crosstrek XV Premium- Marine Blue w/ 5-speed, awesome little car.
I used my original metal trim with the rubber from the repos
67 Cougar
85 Jalepeno Red GT
85 Bright Red RS
88 Smoke Grey GT Hatch
88 Bright Regata Blue GT Hatch
89 Bright Regata Blue GT Vert
Thanks for the help! I plan on keeping my charcoal trim piece and just using the rubber part as well. My new wipes will be here by weeks end so I don't have them now but what needs to be done to just swap out the wipes. Thanks again.
I don't know what brand of dew wipes FMR is selling, however I've been very happy with mine on my capri. It's great not having any window rattles and great sealing. If you can swing it do the rest of the window weatherstripping. It'll make a world of difference.
=Mike=
86 AscMcLaren Capri #026/114 | 11.2@123
86 Mustang SVO - 9L | 14.0@97 | 19psi
My Website (New and Improved)
Custom Wheel Center Caps, Vinyl Decals Racing #'s etc.
I didn't transfer the metal, the newer version I got from FMR seemed just as rigid. Working fine for me.
Original Member of 'The Anti-Cowl Hood Club' and 'The Ten-Hole Mafia'.
=Mike=
Thanks for this explanation!
1984.5 GT 5.0 5 Speed ANALOG
BBK Long Tubes/H pipe/FM
Edelbrock Intake/Holley 600
8.8 w/FMS 3.73s
Steeda Shifter
2010 GT 5 Speed DIGITAL
Track Pack
Pypes Violator axle back
Airaid Cold Air
Here is another post by Mike explaining the dew wipes. Good article
http://www.ascmclarencoupe.com/Proje...ouldingReview/
1979 Mustang Cobra 5.0
2P Red and 1C Black
Stock never goes out of style
Proverbs 3:5-6
My Mustang Story
