You only have to worry about front wheel clearance if the car is lowered. On the F/Z the HTR 275/40R17, 17x9 BBS RX, '94/'95 spindle, Fox A-arm will touch the center tab for the inner fender when the top of the FLCA is parallel to the ground. On the rear the lip needs to be trimmed, there is quite a bit of flashing that should be removed, and if you have the deluxe side moulding the trim studs will need to be shortened to clear the wider tires.
