Man, this is a awesome rare piece of history. You are doing a great job. Do you have any idea how many of these cars were made?
Keep up the great work.
Ford valve cover gasket, 88TC spec:
#F57Z-6584-A
This is the v/c gasket to use. It is a rubber-coated, steel framed gasket that is reusable and holds its shape, unlike the crappy floppy Fel-Pro blue gasket, with the stupid metal inserts, and infinitely better than cork.
83 TC "Clone"
85 Marquis LTS
86 LTD Wagon
Thanks as far as I can tell 9 total made. Mine is marked #003p. Not sure if the p is prototype or production as there was at at least 1 magazine car similar in color but diff BBS and a trunk mounted gas tank. I have a list I've been making with most identified but there a few gaps.
Also thanks for the part# Chuck!
Current FEP:
Past FEP:
pics from the day...it was 95 out and I forgot to eat as I whittled away for 5 hours. Slow progress but progress nonetheless.
Before
After
Inside
Anything look out of place? Suggestions on anything to do while I'm in here? Do the cam lobes look ok and is that scoring ok? 23k on the odo.
Last edited by m81mclaren; 08-22-2017 at 06:18 PM. Reason: Update away from Photobucket
Current FEP:
Past FEP:
That cam looks very dry. You may want to put some oil or break in lube prior to starting it to help avoid wiping a lobe.
Dave
1983 Capri RS Turbo
1981 Black Magic 400 c6
93 F-250 351 5sp 4x4
After 2 tries I finally got the new VC gasket per Chucks specs. Yesterday I was able to Lube the camshaft, installed the very nice new rubber gasket, installed the freshly rebuilt carb, replaced the water to turbo lines, new fuel filter, matched up and installed all but 1 vacuum line. Spent 2 hours making the valve cover shine that can now barely be seen under all the hoses! I trickle charged the battery which is now ready and will borrow a timing light to make sure it is spot on (spec anyone?). I'll try to fire this again tonight after work. Crossing fingers that the exhaust smoke is eliminated from overly rich settings...but not counting on it.
Current FEP:
Past FEP:
Nice Progress...I'd say 10° for timing as a start. I know the newer cars like up to 17° but 10 for a start.
=Mike=
86 AscMcLaren Capri #026/114 | 11.2@123
86 Mustang SVO - 9L | 14.0@97 | 19psi
My Website (New and Improved)
Custom Wheel Center Caps, Vinyl Decals Racing #'s etc.
Thanks n20! Anybody know what this blue electrical connector goes to? It sits right next to the carb by the valve cover...
Current FEP:
Past FEP:
It does not plug in to anything on mine.
Kendal
Thanks Kendal.
Current FEP:
Past FEP:
Still smoking but now almost pure white now. Will get a video up tonight for feedback. With the carb rebuild it fires up as soon as I twist the key and idles great! Time for some deeper detective work so on the list next is timing double check, a radiator hydrocarbon test and the compression test. Need to borrow or rent the equipment to do this as my tool chest is very limited. That should narrow the focus of what's broken but a head-gasket leak is back to the likely suspect.
Been working on my Callaway turbo rabbit gti which had me distracted a bit the last few months but I'm back on track with the M81.
Current FEP:
Past FEP:
Can you see bubbles in the radiator when the car's running? That's another sign of a blown head gasket.
Cheers!
Mike (TopGear85)
Have:
Had:
79PC-San Jose #2890
90GT-Oxford Wht,5spd
No bubbles in the radiator Mike and the oil has always been very clean.
Current FEP:
Past FEP:
Small updates. Working on interior cosmetics to feel like I am making progress again! Mounts for the Recaro's are here, drilled, and test fitted.
The new proper grade hardware to install them are finally in
so hoping the rain lets up this week when I have an hour of garage time. To install the new headliner I have to remove the rollbar. To remove the roll bar I have to drop the gas tank again I previously tested what i though twas the original radio but seems it does not fit properly without dash removal so that's on hold. I can install my new Dashes Direct Gen3 dash cover so that's on the list too.
Small steps but goal is to complete the interior this month., fix the engine once and for all April/May and take it to GoodGuys June 4. Given my track record it's more than a long shot but I've got to have something to shoot for!
Current FEP:
Past FEP:
Glad you're still at it....
1986 SVO Mustang - 1C
hi Kendal! Is that the one in San Jose or other? Details link?
Remember the guy I told you about and he would not let you look at his cars. Looks like he had two, a race car and #10. He died and they were sold at an estate sale. I got an e-mail in January from a guy wanting to sell one but he never got back with me when I e-mailed him back. I think it was #10. Here is a pic of the McLaren plate. I do not have the vin number.
Kendal
Current FEP:
Past FEP:
I am too cheap to comment on what I think it is worth. They did get back with me and I also talked to the guy in the picture that bought the property the cars were on. I have the #2 back up race car that is pictured. Last I heard he wanted $80K for it. The #1 street car is still for sale in Indy too. He only wants $70 for it.
Kendal
I saw one show up for sale in the Facebook Foxbody Addicts page yesterday. He wouldn't specify a price for it, but supposedly redone recently and for sale now.
