What motor mounts do I need. 80 fairmont wagon original 255/c4. Will those mounts work? Putting in a 93 302/aod tbird.
I'm not 100% certain, but I do not believe there is any difference between 255 mounts
and 302 mounts. It's essentially the same block with smaller bores.
Cheers,
Jeff Cook
The original 255 mounts should work.
The mounts with the MN-12 5.0 engine will not even come close to working.
83 TC "Clone"
85 Marquis LTS
86 LTD Wagon
What they said. I think it should be fine, it's a Windsor motor essentially.
