As title mentioned, I threw in a set of new lifters after soaking them in oil overnight, as well as a new set of pushrods. After they were all installed, torqued the rockers to 20 ft lbs and primed the oil pump. I got oil out of every rocker in the engine, so I buttoned it all back up and fired it and it has the same tick that it had before. Sounds too "mechanical" to be an exhaust leak...but I've been wrong before. It's pretty loud, you can hear it while sitting inside the car at idle.
'84 302 HO
'89 302 heads
stock cam, lifters, pushrods, and rockers
Any ideas on what else it could be?
