Results 1 to 13 of 13
    Default Rockers and Clutch pedals
    Two simple questions. First: On a 302 roller motor, how tight should the rocker bolts be? Is there a torque setting or anything?
    Second: When getting a clutch pedal from a donor car do I need the entire pedal assembly, or can I just take out the clutch pedal and related parts without removing the steering column and whatnot?
    FEP Member 4eyed4life's Avatar
    Aug 2008
    Kimberley B.C. Canada
    Pedals: You gotta drop the column...the pedals are an assembly. gotta take the whole thing!
    1984 Mustang GT - BUILT 351W 5spd
    1985 LTD LX - 306, 3" exhaust, 87+ Front brakes
    1985 LTD Wagon - 5.0 5spd project
    1985 LTD LX - 347 Stroker 5spd, Cobra 5-lug brakes, 17" Cobra R's....
    OK Cool thanks!! I just didn't want to do unnecessary work unless it was....well....necessary lol.
    As far as the rocker bolts go......... 0 lash on the pushrod to arm then 1/4 turn. Stock rockers or aftermarket?? Im used to 1.7 crane RR.
    Zo
    88 GT(Saleen SSC Clone).....my
    79 Z7 Zephyr 302/C4....under construction
    96 Ranger...Daily driver
    04 Honda 400ex.....dune slut
    Stock rockers. Excuse my ignorance here but what is lash?
    Pedestal rockers are just torqued to 25 lb/ft...
    There is no 1/4 turn stuff or anything like that. Thats the adjustment method for stud type rockers.
    79' Fairmont ES 2dr Sedan- 3.3L/T-5, Cobra R's, 5.0 front brakes...
    Quote Originally Posted by RacinNdrummin View Post
    I'm sorry, but I disagree. You still need the 1/4 turn preload as mentioned above. Crane sells shims to place under the rocker pedestal to achieve the proper lifter preload. Just torquing to 25 lb/ft could result in lifter damage or at the least...poor performance.
    1982 Mustang GT 460/c-4
    1979 Mustang ghia coupe...original 2.3 turbo 4 speed barn find
    http://s316.photobucket.com/albums/m...zephyr%20pics/
    Also....how on earth do I get the pedal assembly out?! I have been fiddling with it for a day or two and I just can't see what i'm missing. Steering is down, nuts on firewall and under dash are undone, brake pedal undone....is there a trick to this?
    Aug 2008
    there's always more nuts to be undone lol. Keep lookin.
    Quote Originally Posted by mercuryzephyrz7 View Post
    0 Lash is
    when the cam is on the base of the rotation for any cyl, (both valves closed) and the pushrod is just snug (no play) between the lifter and rocker arm.
    Now when you get this point, do you torque to 25lbs ,THEN 1/4 turn or just 1/4 turn......i dont remember??
    Quote Originally Posted by gofastlookstock View Post
    Lifters have a huge amount of free play (relatively of course), the only way you will damage your lifters is if you use the wrong length pushrods. Ford lifters will soak up the tolerances of any production pedestal rocker head using the factory pushrods and std base circle cam (provided the heads arent decked some obscene amount).
    Obviously things change if you add things like massive decking, and reduced base circle cams, but once you get into that, your measuring for new pushrods anyway.
    On a stockish factory setup, simply torquing to 25 lb/ft is sufficient.
    For example, my 306 with .020 GT40 heads, zero decked block, felpro 1011, TFS-1 cam and cobra rockers was just fine with stock length pushrods.
    As long as you can see some visual preload at the lifter, youll be fine.
    x2...
    I see your point and agree.
    In the past, I've run into a couple of situations where I've had what I consider excessive preload ( usually on higher mileage engines...that may have had a valve job or two in the past) sometimes 1/2-3/4 of a turn past initial preload. This why I use the shims to make the preload equal. This is just something that works for me....quite possible that I'm picky about my preload...lol!
